AlgUSF
- Mar 11, 2021
- Melbourne, FL
- 2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
By "voltmeter" I assume you mean multimeter.bad connection at the starter=/=bad starter. This isn’t a diagnostic tactic at all. It’s a guess. Its easy to guess with other peoples money, but it’s even easier to give good advice. a simple test light or volt meter and a second pair of hands (and feet) is all you need to diagnose a starter circuit problem properly.
Continuity and resistance testing usually tells you much more than potential difference (voltage). At rest a high resistance connection reports a similar potential difference as a low resistance connection.
With my money at 4 years old and out of warranty, if I was messing with the starter I'd replace it while I'm in there. The part is $220 from Mopar via RockAuto. Like I said, "just my $0.02".
I had my LCA bushings go out on a vehicle of mine, while replacing the LCAs I pulled the knuckles and had a machine shop press in new bearings in ball joints while I was in there. That is what I do with my own money, but then you know nothing about me.
