Start/stop rubber replacement
GHOST5035
Adam
Louisiana
2019 Jeep Wrangler
Hello all I recently ran in to an issue where my start/stop button peeled off it’s out of warranty. I just want an OEM replacement but I can’t find any anywhere am I just not looking hard enough? It’s the rubber piece and the ring around it any ideas?
OminousSkitter
The Ether
Trek Bicycle
Depending on how smooth it is after peeling, you might be able to put a decal over it. You could probably find one that looks OEM. But the replacement isn't terribly expensive (OK, $75 for a button is kinda high, but I was half-expecting it to be $175+).
SadRobot
Los Angeles
2025 Prius LE
I think with shipping/taxes I paid like $100. When I removed the old module and checked out the rubber over the button it actually wraps around and is glued down. I tried to remove it just as a "what if" and it all ripped apart.
My super smart idea of buying a cheap module on ebay, removing just the "stop/start" rubber and putting into my old module would have never worked.
GHOST5035
Adam
Louisiana
2019 Jeep Wrangler
Thank you for this knowledge
Kawikjai
Kawik jaky
Alexandria Va
Auto
Hey there! I faced a similar issue with my start/stop button, and finding an OEM replacement can be a challenge. You might want to check out my website https://autodetailersofalexandria.com/ for tips on sourcing replacement parts and alternative solutions.
Clouddgail
Chelsey
Ohio
2019 Jeep Wrangler sport s
You're going to need to get a new ignition switch module.
There are a bunch on ebay but I ended up buying one new because I didn't want to risk an ebay buy.
When buying a new switch module do you have to reprogram the fob to the new module or can you just replace and go?
