SS3 LED Fogs - Diode Dynamics - ? Wow!
Slippery Pete
Zach
Central PA
2022 JLUW XR 2.0T
So which bumper would I select for a Willys XR? Sport or non-sport?
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
These images should help for reference.
Jeep Wrangler JL SS3 LED Fogs - Diode Dynamics - ? Wow! 1685036471182
Jeep Wrangler JL SS3 LED Fogs - Diode Dynamics - ? Wow! 1685036479960
Jeep Wrangler JL SS3 LED Fogs - Diode Dynamics - ? Wow! 1685036508743
Jeep Wrangler JL SS3 LED Fogs - Diode Dynamics - ? Wow! 1685036524020
If these images don't help, you may need to check the back of the fog lamps to check the bracket pattern that matches.
Additionally, you can always call or forward images to our customer service team for assistance!
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Jeep Wrangler JL SS3 LED Fogs - Diode Dynamics - ? Wow! 1685036489331
Rhinebeck01
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Well, now over 6,000+miles with the SS3's installed on my JL ....
Performance of SS3's is terrific.
@Diode Dynamics SS3's.. are an add that is easy easy to install and yes, they sure do make a difference.
@Willys_Wonka .... You have had your Diode Dynamics offerings installed for a few weeks now..
The side markers and fogs are a real pleasure right..
Willys_Wonka
PA
JLUW
Yes, I couldn’t be happier with the clear side markers and LED switchbacks so far. Just make sure to also get the resistors that prevent hyper flash.
Rhinebeck01
Rhinebeck01
Retired at 55 ..
Well, 15,000+miles with these installed and almost a year since I installed.... lots of driving day and all night. Mostly interstate miles but a few hundred of those miles on back roads in NY and Florida.
Geeeez, do they light things up forward and to the sides.
Performance of this offering is terrific.
A real pleasure to have the @Diode Dynamics SS3's.. Also, communication with Diode Dynamics is top notch. They are easy to get in contact with and easy to deal with. More companies should be like Diode Dynamics..
Lots of guys/gals ask about the SS3's as they like the look of them. They ask about performance and ease of install. (Easy)
My only regret is that I did not install the Diode Dynamics SS3's sooner!
JJsJL
NE
2022 JLUR ER, 2008 JKU Sahara, 2023 Yukon XL,
Thanks for all the comments on the SS3 fogs. How does the color temperature of the SS3's match the OEM LED headlights?
Anotherwillsmith
Will
Northeast AL
22 JLUSS
Looking into the yellow fogs with amber backlight. Curious is the backlight is possible with factory fog switch or do i need an aux to turn backlight on?
Rhinebeck01
Rhinebeck01
Retired at 55 ..
Are you asking in essence if the white broadcasted by the my SS3 Pro Type M Kit White SAE Fog SKU: DD6197, I have look the same as the OEM LED headlights.. If that is what you are asking, yes, same same.
Grayhound
Michigan
Jlurd
Are you asking in essence if the white broadcasted by the SS3's I have look the same as the OEM LED lights.. If that is what you are asking, yes, same same.
If your running halogens you can buy the amber lights and swap out the lens for white and achieve the halogen temp
JJsJL
NE
Yes exactly. Just wanted to be sure those Diode SS3’s White SAE Fog light color temp matched the OEM LED headlights when run together.
Rhinebeck01
Rhinebeck01
Retired at 55 ..
@Anotherwillsmith
I do not have install instructions on hand but if I remember correctly Diod Dynamics instructs you to hook up the back lights to the side markers which is quite easy to do. You would not want them hooked up to the "factory fog switch".
Yes, backlighting could hook up to an Aux switch or a switch you install.
I do not have back lighting on my SS3's.
Rhinebeck01
Rhinebeck01
Retired at 55 ..
@JJsJL
The SS3 Pro Type M Kit White SAE Fog SKU: DD6197 , I have installed on very very very bright... and as I said match up very well so to speak with the bright white output of both the factory LED high and low beams.
I have my JL set up to run high beam with fogs if I desire and I swear when I run with both high beam and fogs, I could light up very brightly a whole football stadium..
XyloSesame
Ohhklahoma
2021 Tuscadero Sport S
Just installed these today (with help). We tapped into a fused headlight halo lead for the backlights; they come on at ignition. Like @Rhinebeck01 said, you should be able to tap any ignition-on line or side markers as indicated by DD.
Coming from OEM halogens, these kick a$$
Cyber_Jeeper
Utah
2022 JLUR
My SS5’s match the color temperature of the OEM LED headlights. I imagine the SS3’s should be the same.
JJsJL
NE
Great! Thank you. I would imagine your right.
