Spotify Problems & SubWoofer Question
SRJeepin
Stefan
Indianapolis
2025 JL Rubicon 2-Dr.
When I'm using Spotify, there will be moments when it goes quiet for a couple seconds, and then the song continues. Kinda like a record skipping, if ya know what I mean? It happens at random times. Any solution to that problem?
With my 25 JL Rubi, I didn't get the Alpine sound system. The dealer said if I added an aftermarket subwoofer it might screw up the sound system electronics. Hmmmm??? Not sure how I would hook it up either.
Thanks for the help!
#KeepOnJeepin
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Any chance that your nav is giving directions during those gaps? If that's a possibility, press volume up when it happens next. There are two different volume settings.
SRJeepin
SRJeepin
Stefan
Indianapolis
Thanks, but no that isn't the case.
ShellNate7974
Nathan
South MS
2025 Wrangler Willys 4dr
I’ve read that a lot of people complain about lag in the CarPlay use. We have a 25 Willys & have the same issue no matter what digital svc we use for our tunes.
As to adding an amp, I have been looking into the same thing. It won’t fix the lag but my understanding is the audio feed coming from your display/console is digital & has to be converted to an analog signal to feed the amp. Your best bet is to contact www.crutchfield.com they’ll steer you in the right direction.
SRJeepin
SRJeepin
Stefan
Indianapolis
Thank you! Will do!
