Something is wrong...
Goheels050917
Goheels050917
Dustin
Raleigh - Durham, NC
2018 Jeep Wrangler JLU (SOLD - March 2021)
SD-WAN Engineer - Technical Author
Got them off. Shocks aren't compromised. Looks like I saved everything before it went bad :)
Thanks all for helping. Hopefully I wont bottom out anymore :)
Jeep Wrangler JL Something is wrong... 20191106_084415
Fire Burns
Fire
CA
Let us know. Its not always where someone is able to query the forum for a diagnosis and the problem is so easily identified! Kudos all!
Goheels050917
Goheels050917
Dustin
Yep, rides like a dream now. Actually, the fox shocks are pretty nice!
JLUSoCal
IT
From the pic of the rear it looks like your not running the bumpstop that came with the kit. That will cause you to possibly bottom out the shock still. Please verify you have bumpstops that are extended. Should look like this. and placed over the factory "pad" on the axle. The "round" ones should be on the front in the springs. The parts below are from the rough country spacer lift BUT all spacer lifts should have them to protect the shock from bottoming at full cycle.
Jeep Wrangler JL Something is wrong... 2019-11-07_10-50-26
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
Looks like you're correct. I have the same spacer lift and it's supposed to look like this.
Jeep Wrangler JL Something is wrong... 20210425_171115
DWaX
D
Wilmington, NC
Depending on how many times you bottomed out the shocks it's very likely you will see performance degradation sooner than later.
Shocks can take a full extention hit since it's only axle weight, but compression hits blow internal dampers.
WaX
