Jeep Wick
Where are you finding oem LED headlights for $500? The cheapest I see them is $800+.Looking online I can find the lights for about $500 from reputable places.
Don't ask, don't tell. Shhhhhhhh!Where are you finding oem LED headlights for $500? The cheapest I see them is $800+.
Excellent! Make sure that you check with the DAs office. The DA is an elected official and has a duty to serve. Don’t let sweep it under the rug.Got a call from the Sheriff they caught the guys and busted a business that was selling the lights. Apparently 18 people got hit and they are charging them for all of them.
Way over grand theft, which in FL is a 3rd degree felony gets you 5 years in prison or 5 years probation and $5,000 fine. If the value in total exceeds $20k it goes up to 2nd degree and then it’s 15 years of prison or fifteen years of probation, including a fine of $10,000
put in the part # and searchWhere are you finding oem LED headlights for $500? The cheapest I see them is $800+.
Yep this is my planMade my day! Hopefully they’ll get some time behind bars. For future reference, it is nearly impossible to remove your JL grill from the bottom if you have a winch mounted within a Rubicon factory steel bumper. I discovered that fact when I swapped out my grill inserts with gladiator inserts. You would just need to lock your hood.
I've done that and they are still 800-1200. I see carparts.com with an aftermarket version for 650. The only way I can get near 500 is buying them separately used on ebay.put in the part # and search
Thanks for the links. I wish you luck with the 'OE equivalent' but in my experience they are usually poor China knockoffs.I just ordered a set of OE equivalent from HeadlightsDepo Amazon for $660 shipped. Looks like I got the last set There are other sellers on therearound $775
you can order direct from HeadlightsDepo but they are sold out…
https://www.headlightsdepot.com/
Rock Auto has oem replacements for $550 each or aftermarket OE equivalent for $430
https://www.rockauto.com/en/catalog...,body+&+lamp+assembly,headlamp+assembly,10762
eBay has a few sellers with new ones as low as $700 a set
https://www.ebay.com/itm/3748326279...qZKCc6YQha&var=&widget_ver=artemis&media=COPY
I ordered a set of OE equivalent from HeadlightsDepo on Amazon for $660 shipped. Looks like I got the last set but there are other sellers around $775
Should we shut down the member market place and just assume everyone posting there is a theif and criminal?This wouldn't happen if Jeep owners didn't buy the used parts to save a few bucks. It's not just the thief who is a criminal.
No...but we should use common sense. When something is too good to be true, you generally know it. Black markets wouldn't exist without anxious buyers willing to turn a blind eye. It takes two to tango.Should we shut down the member market place and just assume everyone posting there is a theif and criminal?
Not 100% sure if HeadlightDepot is the same as the Depot headlight manufacturer that's been around for decades, but their housings are top notch and just as good, if not better than OEM. Not sure about their actual LED and halogen bulbs though, since the set I bought for my last vehicle was used with aftermarket lamps inside.Thanks for the links. I wish you luck with the 'OE equivalent' but in my experience they are usually poor China knockoffs.
They are not cheap knockoffs. They are CAPA certified, which is what your insurance would probably use in a collision repair. Mopar uses multiple suppliers and they often sell remaining stock as OE Equivalent. Check the link in rock auto for example.Thanks for the links. I wish you luck with the 'OE equivalent' but in my experience they are usually poor China knockoffs.
