I posted an update on this test in a prior post. Likely our postings crossed, but to recap:Thanks Paul!
yes please!
DaveL
Sorry if I missed it or if I'm not understanding, but is the above fix intended to remedy the issue with the center console USB and CarPlay or would you need to plug your phone into the newly-added cable? I'm not understanding and I don't want to take my climate buttons out until I fully understand, but at this point, I'll try pretty much anything. I have read that a possible reason for the CarPlay issues is the cable that runs between the dash ports and the console port is janky and there's a large voltage drop that causes the unreliable performance, so a shorter or better cable between the dash and the center console might help, and your solution above may do just that - I just wanted to verify. Thanks in advance.I mean, if you dont mind, the easiest and simplest solution that I’ve been using since I bought my Jeep almost two years ago is:
Done, works forever.
- Buy StarTech.com 1 ft Mini USB 2.0 Cable - USB A to Mini B F/M - USB Cable - USB (F) to Mini-USB Type B (M) - USB 2.0-1 ft - Black - USBMUSBFM1 from amazon: https://www.amazon.ca/gp/product/B004ZMYEMY/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
- Remove the buttons panel, the one where you have AC/volume controls. Below it you’ll find the a usb cable that connects to it and runs back to the center console.
- Remove the cable above, connect the adapter you bought from Amazon and connect any USB cable to it.
The problem is the cable jeep used to connect the centre console port back to the panel is garbage, thats why it’s so unreliable and sometimes it works better with different cables.
Doing what I said above you completely eliminate this variable.
Also the other USB port on the dash will still work fine
I had most issues while running Google Maps (it would freeze and require unplugging/replugging/power cycle). Even tried the OEM iPhone cable with the adapter and no luck.I hate to be the proverbial turd in the punchbowl here, but I tried the Agoz cable that was suggested and on its 3.8 mile maiden voyage today to drop my kid off at school, CarPlay cut out about 2.5 miles in. iPhone 12 Pro running the latest iOS (16.4.1).You were correct with the cable being the primary issue for CP. but, if you read my first few posts, my suggestion has worked flawlessly for myself and others. Why? I have no idea. But to be up front - I tried everything and this just works. 6 months on and never had one issue.
I tried to order the Agoz cord. Amaxon dot ca cost is ok--about $11 Cdn. Shipping was $30.00 CDN And then there would be duty charges. I wrote the manufacturer; they have no Canadian vendors.
I went to the Agoz store; same shipping costs.
I was ready to buy....
DaveL
Toronto
