Traveller128
- Robert
- Dec 18, 2021
- Oasis Idaho
- 2022 Willys 2 Door 6 speed
- Occupation
- Volvo Master Technician
Over here, several folks swapped a Cummins in.The 6.0 "nodded to be a good engine" might make sense if you can pick up a used one cheap enough. But the idea that you only need a new ficm, high pressure oil pump connector, stand pipes, dummy plugs, egr cooler, oil cooler, head studs, and a new turbo to make it reliable at a cost of $10-15k gives Ford a pass is lost on me. It's a good block? You could ls or hemi swap the jl in that ballpark, but I wouldn't imply it was a win on stelantis' part with your new drivetrain.
