Soft Top Installation Question
Darkcanuck
Canada
2018 JLU Sahara
I installed my soft top the other day and everything seemed ok. My only concern was that I was kind of expecting the back corners of the side windows to have more of a positive "click" when engaging the corner post detail. Perhaps this is normal but they didn't seem as secure as I though they would be on their own. However I moved on and installed the rear window which obviously connects the to sides together and everything seems to be ok. Below are pictures of the side window attachment feature. Is this how everyone else's looks?
Jeep Wrangler JL Soft Top Installation Question 20180726_081219_resized
Jeep Wrangler JL Soft Top Installation Question 20180726_081228_resized
Jeep Wrangler JL Soft Top Installation Question 20180726_081235_resized
Jeep Wrangler JL Soft Top Installation Question 20180726_081250
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
Its normal, that video out there the guy says it clicks in there. It doesn't, the back window keeps it all together. Don't run it with just the side windows and not the back one. They might end up gone.
RussJeep1
Westchester, NY
JLU Sahara
What Bubba33 said. There's definitely no positive click that would make you say to yourself, "ah, I clearly know that it's attached to the rear corner bracket.
And yet it's quite stable as long as it's
1) In its cylindrical "C" track and bead system above
2) Tucked into the lip below and closest to the front of the rig
3) Under and inside the soft top roof above,
4) Prevented from moving away from the rig by the rear window flaps zipperlessly on both sides (driver/passenger) grabbing on to the side window, and
5) The rear window rear flaps tucking under the from behind hardware you hoped would make a click sound on its side.
Darkcanuck
Darkcanuck
Canada
2018 JLU Sahara
Thanks for the feedback. Sounds like mine is normal then. Good to know.
OldGuyNewJeep
Don
CT
Dadawada
Barrett
Raleigh, NC
2018 Rubicon Unlimited, 2020 Honda Goldwing Bagger
Network Technology Executive
I'm considering buying a Premium Soft Top for my JLUR. A couple of hesitations I'm having are:
1) Having to remove so much hardware to put the hard top back on. I wish it could have been designed to leave more hardware on.
2) I have racks on my hard top for my paddleboard and surfboard. I have not seen anything so far I liked as an alternative for the soft top. What have you found?
Bubba33
Saint Louis, MO
I can't imagine it taking more than 10 min to take off all the plastic brackets. How many times are you going to do it a year. I'm only planning on changing tops once a year.
Dadawada
Barrett
Raleigh, NC
I suppose your right. What about racks? Have you seen anything that fits the JL? So far I'm striking out on racks for a soft top JLU.
Bubba33
Saint Louis, MO
Thanks for the info. When your clips are engaged does it look like mine in the pictures?
Yes looks just like yours. Pull on everything when you have it all attached with the rear window,its all together and tight. It's fine the video is misleading,no click when attached.
OldGuyNewJeep
Don
CT
