Soft top hinge squeak
TylerV76
Tyler
Michigan
2021 JLU
Got a hinge on my premium soft top thats driving me insane. Every bump I hit it squeaks. Ive wd-40’d it, greased it with lithium and sprayed it with slide. Any ideas how to make it stop? Im about to just give up on the soft top and go back to the hardtop.
Jeep Wrangler JL Soft top hinge squeak 87AC1317-13AC-419A-BC46-6492390507C6
Jeep Wrangler JL Soft top hinge squeak 29EAF49F-80F1-4E58-B6DC-0AC98849C29B
Jeep Wrangler JL Soft top hinge squeak 6C095B71-7145-4E82-91E1-F9DF1646AB50
Tethmes
Dylan
Michigan
2022 JLWS, 2023 KLR650
Management
Are you sure that's the culprit? That's a lot of grease to still be squeaking.
Swagger
Michigan
Open or closed or both? Squeak or rattle or both? I find that a lot of noise comes from the wheel that rides in the rail, or the spring loaded plastic piece that is supposed to compress when the wheel rests against it. When open, I put a velcro strap around the frame which helps. If closed make sure the plastic supports are inside the rain rails. I find that grease will not help, only keeping tension on the frame to keep it from moving gets rid of the noise. Hope this helps...
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
Open and closed. Squeak. I do also get the rattle from the plastic but that doesnt bother me. Im going to try to clamp that pin in that hinge and see if that stops it. If it does, I may need to have the hinge rebuilt.
boarder140
Andrew
North Wales, Pennsylvania
2022 JL Unlimited Rubicon | 2005 Lotus Elise
Mine squeaks as well, open and closed. More open than closed though. I dont really hear it when the top is all the way down though
edit: its only from the passengers side
Botanicalstig
SC
Na
I think just behind that point you've greased, you'll see a spring (I think it's sort of hidden underneath the rail). Drip some machine lube down in that area. That was the cause my squeak.
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
That was it. Thank you for pointing that out. Ive looked in that general area a dozen times and never saw the spring under that piece of plastic. Got some lube on the spring and it completely stopped the squeaking.
For anyone else having this issue, the spring is behind the plastic piece circled in red.
Jeep Wrangler JL Soft top hinge squeak 1E34E226-F13E-43CA-BF9A-AA30681B49CF
boarder140
Andrew
Glad that thats was where it was coming from! I'm going to grease up mine too
Botanicalstig
SC
Na
Sweet, glad that worked! Mine was squeaky from the factory and it took me a few days to fix. It was really hard to find. Greased all the hinges/pivot points, rail... Over and over, tried different products... Dripped some thick oil on that spring and instant relief!
rvb
Rich
North Jersey
2019 Jeep Moab
Did you need to remove the cover to apply the oil? I have sprayed silicone lubricant and it worked for a day. What did you use to lubricate the spring?
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
I didn't remove the cover. I used wd-40 and was able to get the straw in the crack and spray it. It'll be a week tomorrow and it hasn't squeaked once.
rvb
Rich
North Jersey
2019 Jeep Moab
Thank you very much, I was ready to put the hard top back on!
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
Same. Honestly I still am to a point and may very well do so soon. The squeak is fixed but now Im battling a whistle when there's a cross wind when Im doing 70+mph.
