Snatch Blocks - which to buy?
American Adventurist
West Florida
2018 StingGray JLUR
Back to the OP's question, here is what I consider to be the "best of breed" pulley block. Safe Xtract.
This is the pinnacle in safety and performance for a snatch block. A snatch block is a pulley with side plates (cheeks) that can be opened to reeve the line into the block. Their patent pending “X-Lock” is used to shorten winch lines, belay, connect lines, and distribute loads in bridle configurations. This block has a WLL (working load limit) of 20000 LB and is more than enough for any Jeep recovery situation you will ever encounter.
Safe-Xtract pulley blocks are currently in service with US SOCOM units. They have been validated by the Nevada Automotive Test Center for US Special Operations Command, and have been selected by the US Army’s 1st Special Forces Regiment to be the pulley block training standard within US Army Special Forces Groups. They were selected for use by the West Virginia Army National Guard Mobility Testing Center for Special Operations Ground Mobility training, and have been certified for use by several other specialized Government Agencies.
Buy once. Cry once.
Jeep Wrangler JL Snatch Blocks - which to buy? 71331215_1395698127247010_3842379675460435968_n
Jeep Wrangler JL Snatch Blocks - which to buy? IMG_1560__59297.1558150093.1280.1280
http://www.asroffroad.com/20-000-lb-safe-xtract-pulley-block/
crash13
Toronto
2018 JL Rubicon
Smittybilt makes great recovery products, and a lot less expensive.
https://www.amazon.com/Smittybilt-2...1_1?keywords=2744+winch&qid=1576514743&sr=8-1
#1 on Amazon. I know, doesn't mean it's the best, however it's very solid, 17k lbs, saved me a couple times already. Had to do a completely sideways pull a couple months ago due to a very slippery side hill tight trail. Lots of fun.
On a durability note, I have synthetic line on my SB X20 winch. Do Not let someone with a wire winch line borrow your snatch block. It will leave burrs in the mechanism and degrade your synthetic line.
terryb
Terry
Banning, CA
2019 JLU Rubicon
Without a doubt the factor55 pulley. Just switched out my Warn with one and love it. Lighter weight, smaller than traditional pulley, made in the good ol' USA, innovative design using a soft shackle and a solid recovery gear company. The weight does matter a lot when I'm climbing up a mud-covered hill, pulling my winch line, carrying a tree strap, shackle and my fat ass. Expensive, but worth it.
btkrausen
Bryan
Bardstown, KY
'18 Jeep Wrangler Rubicon
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
SmittyBuilt stuff is mediocre at best. #1 on Amazon means they can afford to pay to play for reviews - it is not "earned".
Nothing SmittyBuilt is "buy it once..." level of quality. Most of it is built in China.
West Florida
2018 StingGray JLUR
This.
Friends don't let friends buy Shittybuilt. Especially when it comes to recovery gear that can seriously injure or kill when it fails.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
It's super sexy but I prefer the more conventional snatch setup but I suspect it's because I'm not a big soft-shackle fan - yet.
I get the logic that if we've replaced wire rope with synthetic rope why can't we replace metal shackles with soft shackles but I'm old and stubborn. I also get that heavy things flying due to a failure while under tension is bad. I've seen the aftermath of a hard shackle and wire rope when a tree strap snapped.
I need to go into the woods with no hard shackles and a couple soft shackles and get really stuck. That way I prove it to myself they are the new way and move forward.
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
I am a bit of a “buy once and cry once” kind of guy so I typically buy the best quality that I can afford. Every now and then, there are products that are very good that do not break the bank and seem to be worthy of taking a chance on which may not be “ultra name brand”.
I am slowly adding to my recovery tools and will be adding a snatch block to the kit. I like the design of a forged steel snatch block and I see three models which catch my eye.
BPA-Racing - https://www.amazon.com/dp/B07YXD4ZD5
GearAmerica - https://www.amazon.com/dp/B07RLV6HZB
Warn – https://www.amazon.com/dp/B00H4PFQFI
Which of these would you buy and does anyone have suggestions outside of these?
I had the same question, OP, but ended up going with these: https://www.amazon.com/gp/product/B07ZXM12XC/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
They might not be as stout as a traditional steel snatch block but I can tell you they are a heck of a lot lighter than steel. I'd rather have the aluminum ring flying than the steel.
I've already used mine to winch out a full-sized Silverado sunk in snow up to the axles.
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
I also try to buy as much as I can from store like Quadratec rather than amazon. Why? When was the last time Amazon produced a Jeep product install video? So, if quadratec has to charge a few bucks more, I’m fine with that.
And, sadly, as big as Amazon has gotten, it's rare to find great deals on their site now.
Same thing with eBay. Very rare.
The problem I have with local stores, which I try to frequent as much as possible, is with their inventory. 99% of the time I ask if they have a product because I cannot find it on the shelf, but they are listed as a distributor on the manufacturer's site, they say "don't have it in stock, but I can order one for you". Well, I can do that too and not pay your mark up. And Amazon will probably get it here faster.
Dkretden
Denver, CO
2020 JLUR 3.6L
Totally agree with you.
Suchestom
Tommy
SUCHES, Georgia
2019 JLU, 1988 YJ, 1983 CJ8, 1979 CJ7
I have off the shelf tractor supply snatch blocks. I don’t know where they are manufactured or who tested them. I got started using them on my equipment trailer winching 25000 pound broken vehicles on my trailer. They perform very well, I’ve never had one fail. They won’t win a cool contest on the trail, but they will perform their job flawlessly. They are a basic design from steel...means they are heavier than necessary, but unlikely to fail.
thelumen
james
usa
Rubicon 392
I’m not here to recommend any one single brand. But my experience has taught me that not all are created equal, and made in USA still means something, especially in the recovery/overhead rigging/tow truck/longshore/logging/fishing world. There are some brands making stuff “offshore” that is upping the game as well. Pros buy brands they trust.
Factor 55 - USA
ARB - Asia
Master Pull - USA
Bubba Rope - USA
Safe Xtract - USA
Skookum - USA
Crosby - USA
Columbus McKinnon aka CM- USA
Chicago - USA
Van Beest - Netherlands
I wrote extensively about it all HERE
Buy quality gear the first time and you will never regret it.
That link doesn’t seem to be working anymore. Do you have a fresh one?
