Side lights to light the ground?
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
https://www.oraclelights.com/products/sidetrack
This is what I did and I love them for exactly that purpose and the turn signal covers the blind spot on the highway as well. If you look at them on my jeep, I had to cut and modify them due to the aftermarket fenders I installed. Normally they're a little longer than what mine look like.
Got a night shot of those?
CRZYCDN
Matthew
St-Lazare
2024 JL XR Unlimited
I pulled of the interior foot well light, so when you unlock with remote/or open the door they come on for a few long seconds. They automatically shut off, then as well I wired up a switch so I have manual control to turn them on when I want or full off (never come on).
Had to use a 3 way switch, custom bracket to hide the switch then a solid state relay (to handle the "dimming" foot well light as the signal, then 4 white rock lights from Oracle).
They are bright, but love them as puddle/approach lights!
Jeep Wrangler JL Side lights to light the ground? 20250115_182435
Mine&Hers
Elmer
Virginia
2019 Jeep Wrangler unlimited Rubicon
Lux magnetic, wired to aux switch and also Bluetooth to phone can turn on from a good distance away.
Jeep Wrangler JL Side lights to light the ground? IMG_5078
Jeep Wrangler JL Side lights to light the ground? IMG_5076
OffRoadMedic392
Dimitri
Clearwater, FL
2022 Wrangler 392
Emergency Medicine
https://www.jlwranglerforums.com/fo...neering-step-slider-lights.95750/post-3003252
I just made these to light up when my Rockslide Engineering power steps deploy, the brand wanted $75+, I made the identical set, plus one extra light bracket for no more than $15 with the lights, and weatherproof connectors.
Perhaps you could wire something like this up and tuck it beneath your side skirt and tap into the courtesy light?
-D
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Looks great! Could we add this photo to our website?
CRZYCDN
Matthew
St-Lazare
For sure, I can try to take a better picture too if that helps!?
You guys have been great to work with/resolved any issues quickly.
Flashtech Lighting
Stephen
Metairie LA
www.flashtechlighting.com
2019 Jeep Wrangler JL, 2004 Maserati coupe, 2013 Porsche Boxster
Business Owner
I might be biased, but I think the Flashtech Magnetic Mini6 are the brightest and easiest to install. They throw off a ton of light and make it easy to see where I’m stepping at night. I mounted them near the rock rails, and they’ve been holding up great.
I wired mine to an AUX switch so I can turn them on whenever I need, but you could also tap into the courtesy lights if you want them to come on automatically when unlocking the Jeep.
Here are a few pics of how they look:
Jeep Wrangler JL Side lights to light the ground? FT-RLM6-W-jeep1
Jeep Wrangler JL Side lights to light the ground? FT-RLM6-W-jeep2
Jeep Wrangler JL Side lights to light the ground? FT-RLM6-W-jeep3
Jeep Wrangler JL Side lights to light the ground? FT-RLM6-W-jeep4
Flashtech Lighting
Stephen
Metairie LA
Business Owner
Thanks! There are a total of four rock lights—two on each side. One is mounted behind the front bumper, and the other is positioned just behind the front wheel on the frame, with the same setup on both sides.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I use the LUX magnetic rock lights and then tapped into my footwell lights inside. When you unlock the car or open the door they come on. Had for 3 years now with zero issue.
im doing an infinite off-road rock light install. Had planned to tap into the footwell lighting. They have a Bluetooth that has a white wire that is supposed to hookup to the footwell. I’m concerned about the fade from the footwell as the footwell lights turn off. Did you notice anything with your leds?
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
Fade as in when the lights turn off they slowly get dimmer as they turn off. Yes they do. That’s not an issues for me as it looks more authentic.
ScotM
Scot
Southern California
I’ll give that a shot. Thanks. I wasn’t looking forward to trying to hook up a relay to trigger when the voltage dropped.
Gregj
Greg
West Texas
A standard relay will chatter when the voltage drops enough, I used a solid state relay and while it doesn’t dim out it does turn off without any chatter.
Gregj
