Side lights to light the ground?
wazzabie
Jeep JL
I would like to have some side lights for when I step out of the JL at night and see what I'm stepping on. What are you using for side lights under the body?
C.Sco
2023 4xe Rubicon
I have some generic LED rock lights I bought on Amazon, haven't gotten around to installing them yet but I had the same ones on my Grand Cherokee before and they worked great.
https://www.amazon.com/gp/product/B01M8OXT2K/
Wire it up to an AUX switch, if you have them (and choose "always on" rather than "ignition" for that switch in the settings menu, to allow them to be on even after you turn the Jeep off).
If you want to have them stay lit for some amount of time when you turn off and get out of your Jeep, but then automatically turn off, you could wire them up with a relay connected to your headlights, so they turn off after your headlights turn off, which is normally I think 30 seconds after you exit the Jeep.
If you want help figuring out the wiring, I could sketch up a diagram for you
C.Sco
2023 4xe Rubicon
I got bored and drew it up
Jeep Wrangler JL Side lights to light the ground? kI4XgUK
The only catch is that your headlights need to be on, to be able to turn your rock lights on, but honestly I can't think of a scenario where you'd ever want your headlights off and rock lights on.
If you don't have AUX switches, then just run a 12V+ constant wire there instead, and add a switch to that wire.
wazzabie
Jeep JL
I have the AUX lights and tow package. I'm hesitant about cutting any of the factory wiring harness or tapping into factory fuses.
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
Have the same.. it’s a wire tap. You can remove it and hardly tell there was anything there.
wazzabie
Jeep JL
Why not just run the lights directly from the AUX wire?
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
8 KC Cyclones wired to the aux switch. If I had the time I'd wire them to a courtesy light circuit as well but for now they work.
Jeep Wrangler JL Side lights to light the ground? KC's
Maverick909
I.E.
www.instagram.com
KC hilites rock lights A+
C.Sco
2023 4xe Rubicon
Because they will either turn off immediately when you turn off the Jeep, or they will stay on forever. If you want them to stay on for only a little while after you turn off and get out of the Jeep, the easiest way is to tap into the headlights, because those are programmed by the factory to stay lit for 30-60 seconds after you turn off and exit your Jeep.
Using a fuse tap, you're not doing anything permanent. You just pull out your headlight fuse, replace it with the fuse tap, then plug the headlight fuse back into the fuse tap, and now you've got a little pigtail wire you can use. To undo it, you just unplug the fuse tap and plug the headlight fuse back into its place.
Jeep Wrangler JL Side lights to light the ground? FHM20200ZPA
THAW
Foster
23 JL4DrRubicon
Looks good, except for one issue: JLs don't have a headlight fuse. The headlamps are switched by the Body Control Module (fuses F26 and F29 are for exterior lights, but they're always hot like most headlight fuses).
To do what you want, you'd have to tap into the headlamp harness downstream of the BCM. I'd recommend using an adapter/piggyback harness so you don't have to cut/tap any factory wires.
C.Sco
2023 4xe Rubicon
Looks goog, except for one issue: JLs don't have a headlight fuse. The headlamps are switched by the Body Control Module (fuses F26 and F29 are for exterior lights, but they're always hot like most headlight fuses).
To do what you want, you'd have to tap into the headlamp harness downstream of the PDC (fuse box). I'd recommend using an adapter/piggyback harness so you don't have to cut/tap any factory wires.
Ah good catch. In that case you could install a timer instead, like this one:
https://www.amazon.com/DROK-Automotive-Digital-Electric-Display/dp/B071XNY72Q
Plug 12V+ constant into one terminal, and AUX switch 12V+ into the signal terminal. Program the AUX switch to be on with ignition, not always on. Set the timer to whatever length of time you want, and whenever you turn off the car while the rock lights are on, they'll stay on for the length of time you set.
wazzabie
Jeep JL
I'm ok with the engine off and the underbody lights on. I would just manually turn them off when no longer needed. I may need them longer then 30 seconds anyways.
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
https://www.oraclelights.com/products/sidetrack
This is what I did and I love them for exactly that purpose and the turn signal covers the blind spot on the highway as well. If you look at them on my jeep, I had to cut and modify them due to the aftermarket fenders I installed. Normally they're a little longer than what mine look like.
Jeep Wrangler JL Side lights to light the ground? 20240211_130735
