Short trip to moab
Ron-Short
Ron
St George, UT
2024 Rubicon 392
Would only a couple days in Moab be worthwhile for someone only looking to do the easy/scenic trails? I am about a 10-12 hour drive from there and would likely stop in St. George [im in la]. Just trying to see if I can make it work on a 5 day round trip.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
You could. Be a lot better if you could squeeze in an extra day. After a day or two, you will wish you could stay longer.
roaniecowpony
Retired Engineer
They're all scenic. I did two days in Moab last October. You work with the time you have. Get the Moab trails book, Trails Offroad, etc.. Plan your time there. There's so many trails that it's overwhelming. Check out the Jeep Badge of Honor app. There were 10 BOH trails in Moab last I looked.
roaniecowpony
Retired Engineer
If you leave at O'dark thirty, you can make Moab that evening. It's a march, but again, you work with what time you have.
ketelhut
Paul
Thousand Oaks, CA
2021 JLUR
I'm in SoCal. Just got back from Moab. Depending on traffic, weather & driving speed, Moab is an 11-12 hr. trip. That's stopping for gas 3 times and eating while driving. I always overnight in the St. George area both ways.
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
Which trail would be recommend to do first if you had a limited time there?
jadmt
jeff
montana
fins and things and then hells revenge. we have done fins and things, hells revenge and Kane creek in the same day. it makes a long day but well worth it.
jadmt
jeff
montana
absolutely as long as you make the most out of the 2 days you have there. We are about 800 miles from Moab and we try and make it a couple times a year. we usually drive it in one shot.
roaniecowpony
Retired Engineer
With a all stock Rubicon?
For a taste of slick rock crawling, Hells Revenge and Fins and Things will get you a taste without too much difficulty. Those are rated 4 and up depending on optional obstacles. Both are Jeep Badge of Honor trails, so don't forget to load the app and check in at the trail head. It's free.
If you want a low rating trail with mostly just bladed road, Gemini Bridges will get you some views and a tour of the country. Rated 2
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Yes, with XR package.
What is your off road experience? Do you have an experienced spotter? Going with anyone?
If you want easy, Onion Creek and Chicken Corners. Fins and Hells (taking the front exit and skipping Hell's Gate and the harder back side obstacles).
You open up to a lot of cool stuff if you're comfortable, the XR can do a ton.
SadRobot
Los Angeles
2025 Prius LE
Can you still get to Gemini Bridges? I had read that was part of the Moab trail closures. :(
I did Hells and Fins in the same day. Was a long day but totally doable.
The one we started but didn't finish was the back way into Arches NP which I believe is Willow Springs Road. Was supposed to be a nice easy drive and we took a bit of a detour to an obstacle and had to turn around because the sun was setting.
Ron-Short
Ron-Short
Ron
St George, UT
2024 Rubicon 392
Any recommendations on where to stay in St. George and Moab?
