Short Engine Runs
OutdoorSpace
Phoenix, Arizona
2021 Granite Metallic 4xe
With the 2.0L direct-injection, oil dilution is a concern for a lot of us. Using the 4xe in Hybrid mode, we are more prone to short engine runs than a Jeep with just a 2.0L in it.
What do you guys do to avoid short engine runs? Is there a threshold oil temp you try to get to if the ICE kicks in? Or are you looking to run it for X amount of time?
I usually don’t use hybrid, and instead force Electric for streets and then E-Save for highway. But there’s been plenty of times where I’ve kicked in the ICE while in full Electric by accident and then wondered how long I should run it before going back to Electric.
Msquad
IL
JLUR 4xe
Sounds like you do the same as I do. When I go to work it is like 8/9 miles to the expressway. I use electric for that and then 18 miles of getting my oil temp up to 190+ the rest of the way.
When I leave work I start with engine and based on how many electric miles I have left, switch over to electric to be able to roll into the driveway at close to 0 left electric. I do the kind of thinking for any commutes taken. Weekend runs, local, all electric.
Had my 4xe 1.5 years and have never seen FORM. I also have half covers on my grill for winter months. Hybrid mode is never a choice for me.
lindaspins
Linda
Burton, OH
2015 JKU Rubicon Hard Rock
This winter I've left my Jeep in Hybrid due to the low temps. There have been a lot of short engine runs, but there hasn't been FORM. I normally stay in electric for local driving and hybrid for highway driving. I only use esave if I want to hold my charge for some reason later in the day, like trails or giving someone a demo.
Lots of us overthink the 4xe. I've reached a point where I'm happy letting it do its thing, and it's working out well.
'21 Rubicon, 35k miles, NE Ohio snow belt.
OutdoorSpace
OutdoorSpace
Phoenix, Arizona
I am a few months short of 3 years in the 4xe here in AZ and haven’t been in FORM yet. ?
Any idea what the magic engine temp is to prevent dilution? @Msquad you mention 190deg, I tend to go to 140deg but that’s a guess at best…
rforbes
Raymond
Seattle, WA
2024 Wrangler Rubicon X 4xe
190 degrees is typically where they say gas will vaporize from the oil. I try and stick with just electric mode and take freeway trips on e-save. If I am having trouble keeping the ICE running when I want it to I just shift into manual.
Ron93YJ
Ron
Pittsburgh, PA
2021 Rubicon 4xe
I’ve got a 21 Rubicon 4xe. Coming up on 3 years of ownership and 43k miles in Pittsburgh, PA. I use E-Save when it’s really cold to prevent as many engine stop/starts. Hasn’t failed me yet! It also probably helps that I’m driving around 50-70 miles a day and my engine has plenty of time to warm up.
sconrad24
PA
2016 Willys JKU, 2021 4XE
So you could set one of the side bars to show your usage percentage. Once I get close to 100% I try to back off the gas pedal a little in electric if my ice hasnt been warmed yet. I havent timed it but its seems like it will give you a few seconds of 100% in electric mode before triggering the ice. Hybrid is more like 50-75%, atleast on the side bar screen on the dash, idk what the actual threshold is.
BXFXJeep
Toronto, ON
2021 4xe Sahara
Manual can get the temps up very quickly, it's just a nuisance when you have to chuck it in reverse it cuts the engine, most times I try to remember to E-Save when I have to do reverse.
I don't think the odd accidental engine start is a problem, I get a few of those, when I forget to put it back into electric mode, Hybrid mode tends to kick on the engine a lot.
Senrusho
Sam
Kentucky
2021 Wrangler 4xE Robicon
I got some 3d printed things off ebay to block off part of the grill when its super cold out, but really the main thing I do to solve the problem is just do more frequent oil changes in the winter.
OutdoorSpace
OutdoorSpace
Phoenix, Arizona
I may have to try this. I’ve been focusing this week on hitting 190degF and dayum my drives are either too short, too cold outside or a combo of both. I’d say 75% of the time it would never get up to that temp.
