Check engine light
Johnnymo30
Chicago
Jeep wrangler 4xe
Hello everyone, I just got two recalls done on my 2021 jeep wrangler 4xe the dealer took it in for 2 days, no harm no foul. After I pick it up though my battery died that same day, and after the battery was fixed that same day my check engine light is back on, does anyone have any suggestions on what I should do, or can jeep do something for me?
Bryce
Bryce
Acworth, GA
2019 JLUR
Needs to get scanned to pull codes to see what threw the CEL. Without knowing the code(s) it's just random guesses.
Johnnymo30
Chicago
Jeep wrangler 4xe
It’s just super wierd timing
us3r1d
robin
CA
2024 Wrangler 4xe Rubicon X
A check engine light after the 95B recall is likely the updated software thinking you need a high-voltage battery replacement.
Johnnymo30
Chicago
Jeep wrangler 4xe
I did have to replace my battery lmao right after the same day
us3r1d
robin
CA
If the battery you mentioned being replaced _was_ the HV battery, the a check engine light after an HV battery replacement is likely the tech failing to refill/bleed the coolant system correctly.
alphawolff
california
2021 JLU
Assuming the HV battery was replaced I second this. Bleeding it requires a special tool that isn't indicated anywhere in the service procedures. Most will fill it and run the bleed routine then think it's good to go.
Take a quick peek under the hood and see if the second from the front coolant reservoir on the driver side is empty.
