Shifter boot - shift linkage squeak
SWIRVN
Ryan
St. Augustine, FL
JLU Rubicon (ordered)
I have about 1200 miles on the 6 speed and the squeak is getting worse. It isn’t the leather binding or the reverse connection and seems like it’s coming from the shift linkage...
Took the cup holder assembly off and couldn’t isolate where it’s coming from. Doesn’t effect driving but the squeak is slowly making my skin crawl!
I was going to wait until my first oil change but I don’t think I have the patience.
Anyone else have this issue and know if the fix?
Thanks!
Jeeplovesmud
Sebastien
Gatineau, Quebec, Canada
JLUR, Kawasaki Ninja 400, Polaris RZR 900 Trail
Hey Swirvn, I'm at almost 5k kms and mine has started doing the same thing. It only makes the sqeak when going left/right. Gonna keep searching if I find something.
SWIRVN
Ryan
St. Augustine, FL
Thanks and I believe it’s the linkage spring under the shift boot. I tried greasing it but didn’t stop the noise. Taking it in this week to see if the dealership can put and end to the squeak. I’ll report back.
JeepCares
Auburn Hills, MI
JL
Hi SWIRVN,
If you are in need of additional assistance while your vehicle is in service, please let us know.
Jeeplovesmud,
We recommend calling Canadian Customer Care for additional assistance at (800) 465-2001.
Darlene
Jeep Social Care Specialist
SWIRVN
Ryan
St. Augustine, FL
I just heard from the dealer and the shift linkage has to be replaced because of the squeak and noises when shifting. Part is backordered though but at least they found the problem.
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
mine starts to squeak at around 3000 miles. then it stopped for couple days, and starts ever since. it's now at 6800 miles and driving me crazy......
Felix22369
Virginia Beach
2018 Wrangler JL Unlimited Rubicon
Mine just started doing this at just shy of 3k miles.. super annoying. Any issues SWIRVN after they replaced your shift linkage? Or has it come in yet?
SWIRVN
Ryan
St. Augustine, FL
No return squeak once they replaced the shift linkage assembly. Took about 5 days to get the part in and had it back in a day after repairs.
I really believe it’s only just the spring in the linkage that is bad but I don’t think they can just change this part and pull the whole assembly.
Felix22369
Virginia Beach
Ok thanks. Guess I will be getting that replaced at my next service appointment along with the host of other issues I have... good times.
GhostDivers
Don
Davidson, NC
2018 JLUR 6sp, 2014 X5 35d, 2020 JLR 6sp
FWIW, I had the squeaking noise just in the left to right/right to left movement of the shift lever. The Dealer removed the center console, removed the cable from the shifter and lubricated the pin, reinstalled...noise is gone.
I think there is a star case or bulletin they could reference.
98021
Arad
Los Angeles
2018 JLU sport Manual gearbox
Mine just hit 1500 miles and i started to hear the noise. sqeak noise when moving shifter to left and right in nutural. took it to the dealer and they did the same thing. removed center consol and applied white lithium grease to cable ends and linkage. noise is gone. there is a bulletin for that shifter noise in their system.
The_Murse
Tim
Massachusetts
2018 Jeep Wrangler Rubicon
No reason to bring to the dealer. This is a common problem and a quick fix. It is very frustrating if you dont know exactly what to do however. It took me some trial and error to find exactly what to grease because initially I used some brush on lithium grease that did not get all the way into the pin that needs to be greased. You need a can of spray lithium grease. You also might initally think you need to remove the shift knob, cup holders, boot ect. Dont remove any of this. Just do the steps below.
1. Remove the (4) 10mm bolts holding the center console down. They are hiding behind little removable panels. Use a small flathead or pick tool.
Jeep Wrangler JL Shifter boot - shift linkage squeak IMG_2402
Jeep Wrangler JL Shifter boot - shift linkage squeak IMG_2403
This will give you the ability to 2. lift up on the center console and raise it about 3-4". Thats all you need. You will see this linkage pin.
Jeep Wrangler JL Shifter boot - shift linkage squeak IMG_2405
3. Squirt the lithium grease on that round pin and work the shifter back and forth and voila, noise is gone. Your welcome.
