IPSCOJL
While driving the other day i got a screen flash in the center display "Service Shifter" then the Check Engine Light & ESS light came on. The jeep is now stuck in 8th and i can not change gears either manually or by asking for a down shift pressing on the gas pedal. Had to pull over to side of the road and shut the jeep off. Tried to restart the jeep and nothing would happen when pressing the start button. I keep trying to get it to restart for 2 or 3 minutes when it finally restarted. The Check Engine Light was still on but the ESS light was not, but at least I could now shift into other gears. Also the ESS function was no longer working at this point. Drove home and was going to take it to the dealer after the holiday and try to see if there was a code. When I plugged in my code reader the CEL when off and reported no codes. So I went for another drive and everything seem normal except for the battery voltage which is all over the place from 12.8V to 14.1V while driving, I think it may have a bad battery or Alt as this should be at 14.V when ever the engine is running. Has anyone else had this issue?
