Shift knob and dashboard 4WD mode indicator differ
MW17588
Morgan
MINNEAPOLIS
Wrangler JL
Hi! Newbie here with a 2018 JL that I love. Just got 8” of new snow in Minnesota... so threw it (well, wrestled it... still working on that) into 4WD. The knob indicator said 4L (down and to the right) but the indicator in the dashboard said 4H. Why the discrepancy? (Not afraid to be called out as an idiot... )
Jeep Wrangler JL Shift knob and dashboard 4WD mode indicator differ B0FC7B03-E374-480B-B8D5-A18CE31FF4BB
Jeep Wrangler JL Shift knob and dashboard 4WD mode indicator differ 4CC9CB03-452B-4514-AA90-B1D4331D528E
digitalbliss
North Alabama
2018 JLUR, 1979 CJ7
My guess is that you don't actually have it in 4L. What speeds are traveling? You will know pretty quickly if it's in 4H or 4L once you get moving.
Gemball2018
Ryan
Ottawa, Canada
Rubicon JL
Not in 4L, the shift knob would be more to the right and on a slight angle. You need to pull to the right of where you are and then pull down. Do so at a rolling speed to make it easier
MW17588
Morgan
MINNEAPOLIS
Wrangler JL
Wow. Thanks for quick responses. I was going about 19 mph and immediately got traction. Got up the driveway on first try (hasn’t happened until I did this). Sounds like I may need to go do some more shifting practice.
BTW, it’s not nearly as easy to get it in gear as my previous Wrangler. Is that common?
robaw
Rob
Iowa
You don't need 4L for 8" of snow - you're driving a tank! Maybe if it was more like 18". :giggle:
seguerski
Josh
Columbus, OH
2018 Jeep JLU Sport S 3.6L Sting Gray, 2014 Jeep MK Compass Latitude 2.4L
Yes, the 2018+ Wrangler re-implemented the Front Axle Disconnect (FAD). Shifts are harder as the synchro and interlock activate (difficulty increases with vehicle speed).
GreyFox
Brandy
Ohio
17 JKU, 19 JL
Yes it will get easier. Mine was pretty tight but it's really easy now. Ok, I just read that so no comment guys.
Sean L
Sean
North Carolina
So this is what 4LO will look like. It is WAYYYY down there compared to 4HI.
Jeep Wrangler JL Shift knob and dashboard 4WD mode indicator differ IMG_1413.JPG
