Service Stop/Start Warning Light
grandpaq
Michael
Miami, FL
2021 JEEP Sahara Unlimited
ok, what is this really? what will the dealer do, and if it's a fuse, can I do it myself?
this light went on a week ago; my Wrangler JL has less than 21,000 miles on it and I wonder if this is a critical thing or a convenience thing.
ps just had the 20,000 check up- of course, this light appeared weeks afterward. Appreciate your advice here.
58Willys
Geoff
Western Washington
2018 JL Sport
More than likely your batteries are going. Try charging the batteries and see if that cures the issue. After charging test voltage and load test each battery separately. If one is bad, replace both.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
I have had this issue for 3 years and unless you have the tech at the dealer pull the code while it is up they can not diagnose. Mine comes up everyday on my way home form work, never on my way to work. They diagnosed it as vacuum...Part on order going on 4+ weeks! Seriously stupid, whoever designed the electrical system in the JL should be forced to make license plates for the rest of their life!
  • Like
Reactions: J0E
Rico1111
Rico
RI
forgot to add, Replaced my batteries with Odyssey (Main) and Brail(Aux) in July so It's not the batteries for me!
grandpaq
grandpaq
Michael
Miami, FL
thanks. good advice.
