Service electronic stability control & start/stop not ready
mwilk012
2018 Ocean Blue JLU Rubicon
Service
I see now you’ve had a troubled history with this Jeep. It may have a bad valve body or connection at the transmission. This is not a problem I’d recommend trying to fix on your own.
sandy.h
Sandy
Oahu
2018 Jeep JL
We’re you having the exact same problem before you put the battery in? It sounds like you blew the fuse. On a second attempt to start it does not use the auxiliary battery.
I recommend disconnecting the auxiliary battery leads at the main battery and testing voltage. Also, test continuity across the posts on the battery fuse.
I was having the same problems before bbbuuuuttttt it would be months in between each incident. And of course when I would take it in, they cant mimic the problem so they can’t fix it. I have suggested for them to look at different specific things when I learn something new from the forums. The tech just kind of dismisses my suggestions.
One more thing I forgot to note though! After I replaced the aux battery, the jeep would turn on, engine on, dash and display would turn on. Then all of a sudden dash and display turn off, but jeep is still on and running. When I replaced the aux battery I took the PDC apart, I thought maybe some fuses got messed up, they were all good. I then proceeded to tighten the four bolts holding the PDC together. Tried starting it again and it worked fine. Took it for a ride, no problems. Now two days later, we got problems!
mwilk012
Service
You should never have removed the PDC. Whoever suggested that to you is a jackass.
sandy.h
Sandy
Oahu
2018 Jeep JL
I can only find the humor in the fact that YouTube had made me think I could be a mechanic.
I didn’t fully remove it. I just took it apart a little. I don’t think I damaged anything though. But it was hard to see everything because of how small the space is.
mwilk012
Service
The pins are just too delicate to recommend removing the pdc for anything other than when absolutely necessary. Removing the fender liner to access the aux battery is much simpler and safer.
Do you own a multimeter?
sandy.h
Sandy
Oahu
2018 Jeep JL
I’m going to get one today since the two I do have are not working. Is there a way to check if the pins were damaged without having to take it apart again?
mwilk012
Service
Testing continuity / resistance from individual components to the top side of the PDC.
Did the dealership ever replace the valve body in your transmission?
sandy.h
Sandy
Oahu
2018 Jeep JL
I do remember them changing something in the transmission but I don’t think it was the valve body. It was the only thing they really did in all the times I had taken it in and them having it for a week at a time.
Archie PJ
SD
2020 Jeep Wrangler Unlimited Sahara Punk"n
I am also getting the dashboard message that my Electronic Stabilty Control function is not working. My jeep has 3,000 miles and cost more than a Lexus. The dealer told me they won’t even look at the issue because I installed a tow bar to tow it behind an RV. They said I voided my warranty even though a major National company installed the tow bar. I am fed up. They can take this 2021 jeep and shove it.
yes, that dealer is incorrect/just doesn.t want to deal with it.
I set mine up myself with a Blue Ox base plate the first month I got it. I.ve been to a couple of dealers around the country with warranty fixes and none have even questioned it.
mwilk012
Service
Do you have a receipt or service record of that visit?
sandy.h
Sandy
Oahu
2018 Jeep JL
I don’t, it was such a long time ago.
I just drove the jeep agin and it did the same thing. This time I had my super chips flashcal and read the dtc codes. U11C2 is a lost transmission message so I’m assuming it might be something wrong with the wiring from the PCM to transmission. What do you think?
Jeep Wrangler JL Service electronic stability control & start/stop not ready 57722AC2-D1A9-4858-8098-079B48E9AB37
Jeep Wrangler JL Service electronic stability control & start/stop not ready 693388F6-5793-467B-A7DB-B1AC07892FAE
Jeep Wrangler JL Service electronic stability control & start/stop not ready CFC1E72E-D56F-43EE-9FA1-004755AB8AE2
mwilk012
Service
I think you need a valve body, or you have a bad connection between the two.
Seems like a bad canbus connector has been relatively common on the JL. They're cheap.
DebB
Deborah
Kentucky
2019 Jeep Wrangler
So I just bought my 2018 Jeep wrangle sport JL in April 2021 and I had for about 6 weeks then this starting happening. I took to Jeep certified dealership, they had for 2 weeks changed the ABS module twice during that time. (Idk why twice) Had home for 5 days and all the lights came back on. And this time I even lost my power steering. Has anyone had this problem and what should I suggest to have them look at. Goes back in tomorrow to try to figure out the problem now.
I have a 2019 Wrangler and I am having the exact same issue. I have to drive it to work daily. Did you find out what was causing it? Someone said maybe the fuses but it don't seem to me to be a fuse issue. Any info would be greatly appreciated.
mwilk012
Service
This warning is generic. Saying you have the same problem is way premature.
