Safe to run wires here?
marktgorman
Ohio
www.underblue.com
Wrangler JLU XR
I am running to pod lights and started to tuck my wires in a nice little slot (my blurry finger is pointing to it) but wanted to double check that I shouldn't be worried about anything such as heat, etc.
Basically I tucked the wires up under that white piece of metal and that plastic tube, I am not sure what runs through there. If this is safe to do, I will tuck the rest of the wires behind that mounts on the left of the photos.
Thanks !! Mark
Jeep Wrangler JL Safe to run wires here? IMG_5517
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
It’s probably fine as long as the wires you’re running are sufficiently protected from abrasion.
I actually ran wiring in the chase itself for a more factory appearance. See post 3 for a brief how-to.
marktgorman
marktgorman
Ohio
www.underblue.com
Wrangler JLU XR
That is a good article, thanks for sharing. So you can open up that chase and run though there? that would be ideal if doable? Is is a ton or work?
Also, glad to know it is a called a chase and cowl sheet metal. I'm already smarter :)
jaymz
Jay
Inland Empire
It’s not a ton of work. Just a bit of a PITA to get the clips opened up. Small screwdriver, some patience and 20-30 minutes of time is all it took.
