cafecito820
Basically, title. My wife and I are planning to install some LED light pods in each of the wheel wells on her 2-door, and I am at a loss for where to safely run the wires from the rear wheel well, under the body exterior, and then up into the engine bay.
The only clear route was inside the actual frame rail itself, but I'm not a fan of having a loose wire just flopping around inside there. That and it would be rubbing up against one of the holes in the frame rail over time, which is also less than desirable. Other than that, I barely saw any good points to zip tie a wire to.
Has anyone done anything like this and got some advice (or pictures) they could share?
