RPM Steering
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Jeep Wrangler JL RPM Steering 1650310122215
Hey Mike @Headbarcode, do what you need to do. There's a lot of ways to get it done. What worked or doesnt work for me, may not work for you. I dont want to be responsible for your gear set. Maybe that one friend can swing by and help you with your 1350s. LOL.
Baba Yaga
NJ
www.youtube.com
Retired LEO
Here's another video. I guess he's spreading bad info too. LOL. At 2:13 and at 18:00, he says 150-160 ft/lbs.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Yeah, I'll have to do some serious homework on that rear axle yoke nut. I'm looking to install my 1350 JE Reel rear driveshaft this Saturday after work.
Headbarcode
LI, New York
Well, my homework came up with a bunch of inconsistent and/or incomplete methods of tightening the pinion yoke nut on the oem axles that still have the pinion bearing crush sleeve in play. Turns out that JE Reel Driveline provides an awesome 4 page set of highly detailed instructions with their driveshafts.
I've had a decent vibration lately, from about 57-64mph with the oem rear driveshaft. I followed the following JE Reel instructions and it's not only smooth as butter now, but it also accelerates with a noticeable increase pep along the whole speed range from a dead stop. That makes me quite convinced that I didn't over tighten the crush sleeve, this over loading the pinion bearing.
I'm going to have to concur with 19 JLUR Bright Whit3 on this one.
Here's the steps I followed...
-with the rear axle on jack stands, remove the wheel and tire weight
-compress the rear brake caliper pistons to prevent any possible brake pad drag on the axle shafts
-after removing the oem driveshaft, perform a rotational torque test of the pinion nut with an in/lb dial beam style torque wrench 3-4 times to confirm the reading and record it for later reference
-prep the new yoke and nut blah blah blah
-torque the nut to 160ft/lbs
-check the rotational torque. If the initial in/lb reading has not been reached, increase the torque in 5lb/lb increments until the rotational torque reaches 5in/lbs over the initial reading
Here's the in/lb 3/8" drive beam style torque wrench with recording dial that I recently purchased for this install...
Jeep Wrangler JL RPM Steering 20220416_201800
Jeep Wrangler JL RPM Steering 20220425_072111
word302
Oregon
JLU
That seems like a much better strategy. The only issue I have is that with the ultra tight tolerance on that pinion bearing, 5in/lbs could easily put you above the spec. The roller bearings in the m220 axle is extremely sensitive to torque. You won’t hear it scream for thousands of miles. I’m sure you’re fine, but having done my own gears AND replaces that tail bearing due to being a hair over the spec, it make’s me nervous. The only benefit is now I can drop my carrier in about 30 minutes?
Headbarcode
LI, New York
According to the JE Reel instructions, which again are the most complete and detailed I've seen with Jeep parts so far, the extra 5in/lbs is meant to ensure that the crush sleeve and bearing isn't under torqued. That can be as bad as over torqued. Also, on what's supposed to be a one time yoke swap/upgrade on a vehicle with some mileage racked up, it's safe to assume that the bearing preload was already starting to relax and that extra touch helps bring it back into spec range.
I fully agree with you in that it won't be proven one way or the other until some real miles get added. I just came across so much inconsistent and/or incomplete methods, such as tightening it until it doesn't wiggle, which doesn't give me a warm and cozy feel. So I thought I'd share what I felt was a great method, along with my immediate results of less drag on acceleration due to a vibrating oem cv shaft on a Rubicon sitting 4" over stock height. Hopefully it can help the next person who finds the same confusion as myself and others seem to have found on both YouTube and Google searches that kept bringing me to relayed threads on this forum. And of course, if I start to develop some issues I will certainly spread the word here on this very thread, so that next person has the full story. Same goes for when, knock on wood, everything stays solid with it. It will be at least a year or so before my 44's get swapped out for a larger set.
Cheers buddy!
Roky
Roky
@Headbarcode and @word302 , good info here…… I’ve always done it by feel, so there’s no way I can explain that, let alone guarantee it will work for the next guy, thus the reason I’ve been keeping my trap shut in this thread……..:lipssealed: …………?
Baba Yaga
NJ
www.youtube.com
Retired LEO
You're always welcome to open your trap here! LOL
Headbarcode
LI, New York
Definitely hard to verbally describe the "feeling", but I know exactly what you mean. For years of truck repair and a slew of brake jobs, the opposed hub bearings needed the right amount of preload with the axle nut. No measuring tools, just that feel. :like:
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Sounds like 3 or 4 ugga duggas to me. :CWL:
Roky
Roky
Yep….. and one sumabictch……I have an old shoulder injury ( football ) it pops at 100ft lbs so then I know I’m close…. The wife been on me to get fixed, can’t get it through to her, that it’s part of my tool collection……. ?
Headbarcode
LI, New York
I save that last bit for lower control arms. ?
Baba Yaga
NJ
www.youtube.com
Retired LEO
Roky
Roky
Nothing better than hearing the "click" at 180lbs.
Yes the “click”…….. my buddy’s got a fancy snap on torque wrench that you have to program the computer built in it before you can use it…….then you get to watch little lights come on and you hear this lame as beep, c’mon… WTF is that… I mean it’s probably precise as it gets, but I’ve been wrenching for, well, forever and never had any problems with the “ click “………… ?
