Rough Idle?
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
Any updated on this issue ,, any one got it fixed?
Wow talk about timing! I literally got off the phone w/ the dealer 15 mins ago regarding this. There is a tech bulletin for a software update for and idle issue. It's regarding a rough or spiking idle when coming to a stop.
3 weeks ago we noticed the idle got a little rougher (negligible but noticeable to me). Then 2 weeks ago my wife told me that twice when she started the Jeep it idled really rough. For her to notice and say something means it was bad.
They are going to push the software update for me. The software came out on 10/16. I'll let you know what happens or ping me in a few days if I forget.
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
Thank you , waiting to hear from you the good news
Updated the software yesterday. I haven't really had a chance to check it yet as it is my wife's but I'll check it over the weekend most likely.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Mine idles at around 1400 when started cold, normally around 800 after that. Seems like an ECM issue.
jeremyjeep
Jeremy
Jeep, USA
JLUR
Try this for the Jeep Wrangler 2018 rough idling problem. Source: https://www.jlwranglerforums.com/fo...r-jl-wrangler-check-your-jl-for-recalls.9784/
NUMBER: 18-041-18 REV. B
GROUP: 18 - Vehicle Performance
DATE: October 16, 2018
SUBJECT: Flash: Powertrain Control Module (PCM) Updates
OVERVIEW: This bulletin involves reprogramming the PCM with the latest available software.
MODELS: 2018 (JL) Jeep Wrangler
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA, EMEA, LATAM and APAC.
NOTE: This bulletin applies to vehicles built on or after **September 11, 2017 (MDH 0911XX) and on or before September 26, 2018 (MDH 0926XX)** equipped with a 3.6L V6 24V VVT Engine Up Grade I W/ESS (Sales Code ERC).
NOTE: The RRT portion of this bulletin applies to vehicles built on or before February 27, 2018 (MDH 0227XX) equipped with a 3.6L V6 24V VVT Engine Up Grade I W/ESS (Sales Code ERC).
SYMPTOM/CONDITION:
Customers may experience one or more of the following:
• **Excessive blower fan noise when the A/C is on MAX output.
• Intermittent rough idle or idle surging, when coming to a stop (Automatic transmission equipped vehicles only).
• Random Electronic Stability Control (ESC) lamp illuminates in the Instrument Panel Cluster (IPC).**
• Driving at vehicle speeds while in first gear and shifting into neutral, a message 9Shift to 1st gear not allowed9 message appears in the Electronic Vehicle Information Center (EVIC) when conditions are not met (Manual transmission equipped vehicles only).
• 3 km (2 mph) difference between cruise set speed versus actual display speed.
• During cold vehicle operation and the use of cruise control on vehicles equipped with an automatic transmission, the engine RPMs may drop below idle speed while cruise control is engaged, this may occur if the customer presses the accelerator pedal to achieve a vehicle speed greater than the cruise control speed and then releasing it.
• Radio or IPC may reboot (flash off/flash on) during an Engine Stop Start (ESS) shutdown in cold conditions with a battery temperature below 12° C (10°F).
DinaMohr
Dina
Idaho
2017 Jeep Wrangler and 2020 Jeep Grand Cherokee
That was happening to my 2017 Wrangler with 59k miles. I cleaned the throttle body and it has improved a lot. But it still has a stutter now and again.
