Rough Idle
jeremyjeep
Jeremy
Jeep, USA
JLUR
Leights7
Leighton
Calgary
2018 Jeep Wrangler JL
Same for me. Its in again and they say its perfect....annoying!
Hi. How many miles? Mine is still rougher than I'd like but I will say it got significantly smoother after about 2500 miles.
snelldogg
snelldogg
greg
new jersey
GC Sahara ETA 2/3
Over 6k now.
gofastguy
Ohio
2018 JL Rubi 2019 WK Trailhawk 2015 Mustang GT
I'm in the same boat with the rough idle...annoying but not so bad that I want to deal with the frustration of going to the dealer and having them tell me it's normal in that condescending way that they do lol
Does anyone know if the reflash for the blank 7 inch center screen should have fixed this? I already had that one done.
Leights7
Leighton
Calgary
I'm having mine checked for the TSB software upgrade. My idle isn't bad - much smoother when the vehicle is warm. During a cold start during high idle, it skips/bumps/misses every few seconds.
JeepCares
Auburn Hills, MI
JL
Hi gofastguy and Leights7,
The TSB reference by jeremyjeep does mention a rough idle, and I have included the TSB information below. I would recommend referencing this to your dealership at your next service visit to see if it applies, and please PM me if you have any questions.
NUMBER: 18-041-18 REV. B
GROUP: 18 - Vehicle Performance
DATE: October 16, 2018
SUBJECT: Flash: Powertrain Control Module (PCM) Updates
OVERVIEW: This bulletin involves reprogramming the PCM with the latest available software.
MODELS: 2018 (JL) Jeep Wrangler
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA, EMEA, LATAM and APAC.
NOTE: This bulletin applies to vehicles built on or after **September 11, 2017 (MDH 0911XX) and on or before September 26, 2018 (MDH 0926XX)** equipped with a 3.6L V6 24V VVT Engine Up Grade I W/ESS (Sales Code ERC).
NOTE: The RRT portion of this bulletin applies to vehicles built on or before February 27, 2018 (MDH 0227XX) equipped with a 3.6L V6 24V VVT Engine Up Grade I W/ESS (Sales Code ERC).
SYMPTOM/CONDITION:
Customers may experience one or more of the following:
• **Excessive blower fan noise when the A/C is on MAX output.
• Intermittent rough idle or idle surging, when coming to a stop (Automatic transmission equipped vehicles only).
• Random Electronic Stability Control (ESC) lamp illuminates in the Instrument Panel Cluster (IPC).**
• Driving at vehicle speeds while in first gear and shifting into neutral, a message 9Shift to 1st gear not allowed9 message appears in the Electronic Vehicle Information Center (EVIC) when conditions are not met (Manual transmission equipped vehicles only).
• 3 km (2 mph) difference between cruise set speed versus actual display speed.
• During cold vehicle operation and the use of cruise control on vehicles equipped with an automatic transmission, the engine RPMs may drop below idle speed while cruise control is engaged, this may occur if the customer presses the accelerator pedal to achieve a vehicle speed greater than the cruise control speed and then releasing it.
• Radio or IPC may reboot (flash off/flash on) during an Engine Stop Start (ESS) shutdown in cold conditions with a battery temperature below 12° C (10°F).
Jennifer
Jeep Social Care Specialist
ibrahim_86
Ibrahim
Saudi Arabia
Wrangler JL Sahara 2018
SYMPTOM/CONDITION:
Jennifer
Can you please FWD this TBS to your Saudi Dealer ! Since day one I have that rough idea and now it seems to be increasing !!! And the dealer knows nothing at all in how fix this issue
My worste desision in 2018 was to buy a Wrangler !
jeremyjeep
Jeremy
Jeep, USA
JLUR
SYMPTOM/CONDITION:
Jennifer
Hi Jennifer. Question for you - How come the dealers rarely know about TSBs, or Star cases? I realize people at the dealership might not pro-actively read TSBs and Star cases, but when a customer clearly explains a symptom, how come the dealers don't even bother searching for a TSB or Star case that might address the vehicles symptoms? Yes, I know they look up VINs and if it matches a recall, then they pick up on that, but why do customers have to bring in an internal FCA document and the dealer responds "I'll be darned"? Not just my experience, but as you read the threads here on the JL Forum, it is full of these examples of the dealers being clueless and/or too lazy to look for a TSB or Star case in their internal systems? Even a 2 min external search in Google for (example) "2018 JL Jeep Wrangler rough idle" finds it.
ZEN357
Pittsburgh, PA
Jeep Grand Cherokee SRT
Auto Mechanic
Check the Engine Mounts and re-torque the bolts, then I swap out the plugs for a good set of performance ones as well as the wires and coil packs. Go with MSD. That's what I'd do. I have no trust or belief that any dealership will help anyone after the things I just experienced with them.
