Rock Krawler
Allen0jason
Jason
TX
06LJ,
Was looking on the website and noticed they have a 2.5 mid arm and 2.5 mid arm no limits. I'm curious what the no limits Means versus the standard. Researching lifts for two-door hardtop 2.0 Rubicon.
Roky
Roky
No limits refers to the sway bar links….. they’re a double heim joint designed specifically for the Rubi electronic disconnect…
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Has anyone figured out how to make these links quiet? Driving around just a bumpy street sounds like a guy banging pots and pans around. My rear links have a grease fitting from Rock Krawler.
Roky
Roky
Yours are the only ones I’ve heard of that make noise…. Mine are almost 6 years old, and they’ve never even squeaked let alone sound like pots and pans clanking….. The only time I’ve heard anything from mine is when they loosened up. I drilled out my sway bar so I could use 9/16 bolts now there’s no play in them….
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
How old are your No Limits joints. They used to be a two-piece bushing design, but have since gone to the single bushing design in the Krawler joints. I have given thought to seeing if I can either install the adventure series rubber joints in lieu of the Krawler bushings. The single piece bushings are much improved over the two-piece design.
Rangemaster
Nevada
Business Owner
2 years or more.
Rangemaster
Nevada
Business Owner
Crap, I am so done with them.
Roky
Roky
