Petey003
- Adrian
- Mar 29, 2018
- Southern Vermont
- 2021 RAM TRX, 2018 JLUR, 1996 H1 Wagon
- Occupation
- Director of Commercial Operations (TWF)
- Vehicle Showcase
- 2
Hey,Our 2.5" lift is nominal by the front lift height. The rear lift is less than 2.5 as the system is design to level the vehicle as well. Some rate them differently. That is the lowest lift height we have for the JL. Our 3.5 sit exactly 1" taller than the 2.5" coils.
The rear inside part of the fender piece that can be pulled out does protrude into the wheel well and 37's can rub on it without bump stops. Did you install our adjustable bump stop sets?
Question here. I have the 2018 JLURubicon 4 Door. I purchased and installed your 2.5" X Factor Suspension.
I feel like my front end is a bit higher than my rear. Would it make sense that my nose is higher than my rear? If so, is adding a 1" or .5" spacer in the rear a good idea?
Thoughts here? I definitely don't want my nose up in the air.
