Right rear wheel locking up during normal braking
OutdoorSpace
Phoenix, Arizona
2021 Granite Metallic 4xe
Last night pulled in, put into park and before shut off I could hear what I think was the ABS module cycling for an extended period. It just kept going, and going, and going.
I finally turned the Jeep off and the cycling stopped.
Today, first drive and first normal set of braking for a light the right rear tire essentially locked up. So tire screeching from that side during a run of the mill slowing down. Happened several other times during that drive unless I really babied the brake pedal.
Anybody else experienced this? Is the cycling some indication of the ABS module going bad and hence this braking issue?
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
I experience this in a JK Rubicon. I almost took out a pedestrian on the sidewalk because the Jeep unexpectedly veered right onto the sidewalk when the right rear tire locked up. In my case it was an anti-lock brake sensor that needed to be replaced along with the wiring harness to that corner.
Just remember, all this anti-lock braking computer BS is a safety feature.
Westymike
bio.site
2021 JLR 2.0 8spd Auto
Digital Marketing / Brand Manager
I had that problem on the Rubicon trail and a few other trails while in 4wd. My aux battery also died at the same some so I bypassed the aux battery and drove it home no problem, but it came back again on another trail. So, I then replaced the ABS sensor on that wheel and it hasn’t come back yet. 🤷‍♂️
Jeep Wrangler JL Right rear wheel locking up during normal braking IMG_3053
