Headbarcode
- Mike
- Aug 16, 2018
- LI, New York
- 2019 JLUR Stingray 2.0 turbo
- Vehicle Showcase
- 1
Sounds like a great catch and fix on that issue.My Son and I just finished our Reid setup last night. We also installed Synergys new compound lower TB bushing and upper. Check this out.... We always check torque setting before we loosen, but upon removal we noticed the bolt had some play. Come to find out the factory axle side bracket where the lower TB bolts to bolt hole was too big or loose and bolt had play! We took 2 stamped HTS steel plates we had and center drill holes to fit bolt sleeve tight. Welded both front and rear plates then painted. Torqued everything down and boom ZERO play. Who would of thought a factory bracket at 5k miles would of had play....
We have also never had a single issue with Poly. Just is on point and they always answer. We have had 1 return in 15 orders, shipping to CA is literally 2 days. Same for Synergy. Both get props from me.
Synergy and Poly Performance are the same company.
