Reid knuckles
caratnic
Boris
Bozeman MT
Jeep Wrangler
Anybody with Jeep JL with dana 44 widetrack axles used the Reid knuckles? I've heard of some people using these knuckles have to grind and modify them to make them fit? Anybody with any experince with these? Would like to get rid of the aluminum knuckles ....
I have had them on my 2018 Rubicon for a couple years now.
There is no grinding to make them fit. However, the adjustment for the steering angle stops are solid and you can file or grind them to get the desired maximum angle. Or you can leave them as is and lose a little angle of maximum steering. I chose to grind them to allow for the stock maximum steering angle. They are small nubs and the grinding is light duty.
Roky
Roky
Been running them over 3 years now, zero issues….. unless something’s changed, the knuckles I got were machined perfectly and fit like oem……pics and thoughts here…
https://www.jlwranglerforums.com/forum/threads/crystal-rubi-build….61821/post-1398759
caratnic
Boris
Bozeman MT
Jeep Wrangler
Awesome, I saw some review at a website saying they had problems, not sure on vehicle, but just made me a little nervous, so I though I'd post before I made any decisions.... thank you all for making me feel more comfortable ha ha ha, I will be ordering now
GoatHerder
Illinois
Jeep Wrangler JL Rubicon Recon Wrangler TJ
I was looking at these today too.
caratnic
Boris
Bozeman MT
Jeep Wrangler
We need a father's day deal, best ive found so far is 10% off
GavinH
Gavin
JLUR
I also have these knuckles on the d44 and installing them was straight forward no extra work. Been able to get up to 57 mph on the whoops and open sand, 2.0 4cyl is now my limiting factor
Jeep Wrangler JL Reid knuckles IMG_0181
Jeep Wrangler JL Reid knuckles IMG_0944
caratnic
Boris
Bozeman MT
Jeep Wrangler
Awesome! Just order 10% off was the best I can get, going to do new ball joints while I'm in there
caratnic
Boris
Bozeman MT
Jeep Wrangler
I've read some things in this forum about shifting into 4H before pulling the axles? Then you don't have to mess with the FAD module? Is this true or better to disassemble the FAD before pulling the axles?
JT1
Broken Arrow, OK
2021 Willys Gladiator
100% true. While your jeep is running, shift it into 4H and roll back and forth a couple times to make sure it engaged. I didn't bother unbolting the front axles from the unit bearing either, couple fewer steps.
Are you planning on replacing balljoints at the same time?
caratnic
Boris
Bozeman MT
Jeep Wrangler
Doing the Reid knuckles and ball joints, then installing new metal cloak tie rod and drag link
caratnic
Boris
Bozeman MT
Jeep Wrangler
Also can I pull both axle shafts at once, or should I pull one side, do ball joints, then put it back together, then remove the other side?
I pulled both sides apart and pressed the balljoints out and back in all together.
caratnic
Boris
Bozeman MT
Jeep Wrangler
Sounds good, thank you!
