Regeared front axle; help identifying small metal rod found (update: solved, not from diff)
azwjowner
Phoenix
I'm finishing up regearing my m186 front, kept the open carrier and just swapped to 4.56, and after putting everything together I found this small metal rod on the ground underneath where I've been working. It looks broken off on one end. I checked my carrier and the roll pin is still there (and doesn't look like this anyway).
Can't tell if it fell off a tool or something in the diff from all my dead blow hammering to get the carrier in. Any ideas?
Jeep Wrangler JL Regeared front axle; help identifying small metal rod found (update: solved, not from diff) PXL_20231224_171553754
Chevymitchell could tell you if it's part of your differential.
word302
Oregon
JLU
That doesn't look like anything out of your diff man.
azwjowner
Phoenix
That's what I like to hear, thanks. I have completely disassembled an open diff carrier before so didn't think so, but this gearing project has been a bit of a nightmare so the reassurance is appreciated!
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
@chevymitchell - This is my last question, I promise!
That’s def not a piece of your diff. The only thing that remotely looks like that is the pin that holds the spider gear dowel in. You’re good to go, for sure.
Old Jeeper
Don
US Army Infantry, IT Engineer
I have done several Jeep axles, gears you name it and I don't recognize that. Here ya go, I am buttoning it up for a client and I don't see that anywhere, nor does it job my memory... This is HIS Front Axle!
Jeep Wrangler JL Regeared front axle; help identifying small metal rod found (update: solved, not from diff) 07052010675
azwjowner
Phoenix
Thank you all so much for your help -- I think I found the source; one of my dead blow hammers has a hole in it that matches the pin size. Drove the Jeep and nothing exploded so I think it's good :like:
