Recomendations for alignment
firedog561
Jason
Eastern Shore of MD
2018 JL Moab
I have a 18 Moab edition. I have the Mopar lift, Alpine front lower control arms, adjustable front and rear track bars. What should I get the alignment set at?
SilverRubi
Daniel
Kansas
2019 JLUR
You should use the track bars to center the axle under the Jeep. You can do that by measuring the frame to the tire and adjusting the track bar to center it.
Use the lower control arms to adjust caster. You want around 6 degrees of caster. Slightly over 6 would most likely be better than slightly under. Camber isn't adjustable. The toe shouldn't have changed when adding the lift.
firedog561
firedog561
Jason
Eastern Shore of MD
2018 JL Moab
Thanks
