Rear Diff Service and Determining Gear Ratio
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
I'm pulling my rear diff cover this weekend to clean up the diff and swap fluid. What's the best practice here; drain, wipe down spray with brake cleaner, repeat wipe?
Also I bought this Jeep lifted on 37's (2021 Rubicon Diesel) so I really don't know if it's been re-geared. Is there a way to count the teeth to determine the ratio?
beast40
Cary, NC
2018 JL Rubicon
Jack it up. Mark your Drive shaft with paint or marker. Spin the tire a full rotation and count how many times the driveshaft turns.
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
Pinion may be hard to see. I would do the tire/driveshaft calculation.
Grayhound
Michigan
Jlurd
I would look at the menus of either the tazer or jscan to see if it will tell you.
I'm 99% you're going to find the 3:73s
jadmt
jeff
montana
pretty to get ballpark but using this calculator. take your actual tire measurement not advertised size and see what your rpms are at 60 or 70 mph in 8th (0.67) or 7th (.84) or 6th (1.0) if you use 3.73 and that is what you have the rpms should match the calculator
https://purperformance.com/p-29669-rpm-calculator.html
Lofty
Casey
Ohio
JL Wrangler
Ring gear should have the ring and pinion tooth count etched into the OD. clean with a rag and you should be able to see it
flick2614
flick2614
Randy
AZ
Stupid question: what does OD stand for?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Outside diameter of the ring gear will have the gear ratio etched into it
Heres a random example I found, 11 and 41 indicates 11 teeth on the pinion and 41 on the ring gear. 41 divided by 11 equals 3.73 ratio
Jeep Wrangler JL Rear Diff Service and Determining Gear Ratio IMG_8205
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
