Rear Camera Optical Cable Extension (add length)
RubiBlueJLU
Missouri
2021 JLUR Diesel
Structural Technician
Anyone here managed to find an optical extension cable for the rear camera? (JL models)
Not a longer one from the tailgate plug-in to the camera, but one to just add length. Maybe 3 feet?
Plug one end into the factory tailgate connector and on the other end, plug the factory cable into it.
Want to be able to unplug the camera without getting into the tailgate space.
Any help appreciated.
Terrymo
Terry
2023 JLURXR 3.6 ET
These guys will build you whatever length with whatever ends you need. When I added the Motobilt tire carrier I chose to buy an extension cable.
Jeep Wrangler JL Rear Camera Optical Cable Extension (add length) IMG_0487
RubiBlueJLU
RubiBlueJLU
Missouri
2021 JLUR Diesel
Got a web site? Can’t click and go.
Thanks!
jax501
'24 JLR
Terrymo
Terry
2023 JLURXR 3.6 ET
@Terrymo is it the "black fakra plug to fakra jack using PE-C100-LSZH Coax" that is required to extend the backup camera cable?
Asking because there are so many different colors with ever so slightly different connectors based on color.
https://www.pasternack.com/images/ProductPDF/PE38748A.pdf
https://www.pasternack.com/fakra-plug-fakra-jack-pe-c100-cable-assembly-pe38748a-p.aspx
I have a 2023 with the OEM front trail cam in addition to the rear back up cam. My connector is black and that is a screenshot of my order form. I sent pics to Pasternak tech support of my camera and cable connectors and they told me what to order. Sorry, I don‘t know what variations there may be from year to year, with or without front cam etc.
billjr
Norwalk, Ct
2022 Wrangler Rubicon eTorque
Retired Telephone Plant Engineer
Depends on what connector is on the existing, they start here I forget which connector they use back there.
https://www.amazon.com/s?k=optical+...9&ref=nb_sb_ss_p13n-expert-pd-ops-ranker_2_23
RubiBlueJLU
RubiBlueJLU
Missouri
2021 JLUR Diesel
My connectors are white. 2021
Jeep Wrangler JL Rear Camera Optical Cable Extension (add length) IMG_8602
Jeep Wrangler JL Rear Camera Optical Cable Extension (add length) IMG_8601
RubiBlueJLU
RubiBlueJLU
Missouri
2021 JLUR Diesel
So, they are the White Farka Plugs. I need a chord with a male and female, to make an extension chord. Man, the colors (styles) that are available are crazy.
Looks like I can get a premade one off of Amazon, though I will have to "deal" with the length(s) that are available. $16 ot $50, depending on length and supplier (no free shipping).
Thanks to all for the help!
RubiBlueJLU
RubiBlueJLU
Missouri
2021 JLUR Diesel
Did a little more digging and discovered that the 2021 Rubicon rear camera is a Unicorn.
Uses plastic tabs for mounting, instead of the typical 3 screws.
Farka connection is a type A (white), while the typical connectors are type B (black).
Oh the joys!
RubiBlueJLU
RubiBlueJLU
Missouri
2021 JLUR Diesel
So, another update.
They sell extension cables with Farka “Z” ends. Seems like a universal fitting the fits all the Farka ends.
Bought a 10’ one. Plugged it into my 2021 camera cable and it works fine.
Thinking the “Z” fitting might work several different years. Might make it easier to use those carriers needing a bit more length.
Amazon for the win!
https://a.co/d/0gRPtjjG
