Rattle behind dash - driver side
JeepCares
Auburn Hills, MI
JL
I have the rattle and have not resorted to pulling the dash out yet, but it's going to happen.
In so I can read all this stuff later. Mine is when I play songs and it is always at the same frequency.
Hi jdhunt0 & DOOKEY,
Sorry to hear you are experiencing this concern as well. If you decide to have your dealers look into this, please do not hesitate to send us a private message. We’d be happy to have your concerns documented and connect you with Case Specialists who can work with your dealers to help find a potential solution.
Jeep Social Care Specialist
jdhunt0
Kentucky
2019 Wrangler Unlimited
My dealer said the same thing he has about every issue I have brought to them. All Jeeps do it. It's normal.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Thanks Mark. I'm not taking my Jeep to the dealership for a rattle that I can fix myself. They'd laugh at me against the amount of work I've done to my Jeep.
Maybe Jeep could come up with an end user benefits program for those of us who choose not to go to the dealership? Wouldn't have to cost you money. You could just offer people a discount off retail for more Jeep product they want??
Just an idea that helps you and helps the end user.
W1ck3d
Toledo
2019 jl rubicon
Did anyone mention the clutch position plug yet? That maybe the cause... Probably came loose.. You can just tape it into a secure place
JimLee
Jim
Too damn close to Death Valley
'19 JLU
My wife dropped a screw down my defroster vent, immediately after I yelled "dont touch tha...aw sheet". She probably broke into your jeep and did the same, she's loco like that.
Keith
Keith
Hot Springs Village, AR
2019 Jeep Wrangler JL Sport 2 dr, 2017 Ford Mustang GT Premium Convertible, 2018 Ford Fiesta SE, 2017 Tiffan Allegro 36LA, 2018 Honda CB500F
I bought a new Ford F150 in 2015. Just after I picked it up the speedometer reset it's zero at the 70mph mark. I took it in and the dealer replaced the speedo. For the next 2 years I had an annoying dash rattle. I knew I would but you can't go around without a speedo. It was driving me crazy but there was no way I was taking it back to the dealer. About a month before I traded it I finally lost my mind trying to find it and I went all Tarzan and pushed really hard against the upper right corner of the instrument panel. There was a loud audible "snap" sound. After that, no more rattle.
jeepfan30
Bend, OR
2018 JLUR 2.0
I found mine to be the panel that holds the headlight switch. When I heard the rattle I could push that panel with my finger and it would stop. I ended up with a tiny piece of black foam rubber just a little larger than the size of a toothpick and used a plastic knife to push it in where that panel meets the dash. That took care of it.
This was the source of my very annoying rattle/chirp when hitting bumps. Thanks for posting, my quiet Jeep feels like new again.
EngenZerO
Ozzie
Denver, CO
2019 Jeep Wrangler Moab
So your rattle sounded like mine. Lower pillar/speaker and center steering column.
My fix was 3 part
1) I have ACC so I added some foam to the plastic trim pieces above/behind the visor
2) Stuck my arm behind the lower driver instrument panel. I traced a wire that is attached to the steering column. When fuddling around with it sight unseen I realized there was a clip that wasn’t secured! With a lot of guess work and feeling around with my fingers secured it back into the hole the clip sits in. May have been easier had I just popped out that panel!
3) I think this is the fix that helped the most! Used a torx bit and tightened up the visor screws! 3 on each side of the Jeep. Driver side was insanely loose.
Those fixes fixed that annoying rattle when hitting bumps and stopped that sound that sounded like it was coming from the lower pillar/speaker area.
Steven
Moody, Al
JL Jeep Wrangler 2020
Anyone experience this? 2018 JLUR 17k miles. Almost sounds like it's behind the air conditioning vent top left of dash or under the speaker grill.
Rattles over bumps. Just started recently I believe due to hitting a massive pothole on the left side.
Yep. Just fixed mine yesterday. It was a wire underneath the drivers side dash. I laid down under the steering wheel and felt with my hand deep under close to the fire wall and felt a wire male/female plastic connector. It was apparently touching something to cause the noise. I pulled it away gently and even pulled it snug on both ends. I took it for a test drive and the noise was gone. I thought about taking it to the dealership but when I talked to the service writer he said he had never heard of such a noise. Really ? I decided to fix it my self and I did. The rattle from the tail gate I also fixed because of you tube. Hope this helps your problem.....
MOJO1970
Michigan
2014 JKU
As simple as this sounds…make sure your visor is snapped securely in place. Mine was loose and it rattled but sounded like it was cool from the dash behind the instrument panel, once my son snapped it in place the rattle went away!
Grayhound
Michigan
Jlurd
Found my rattle today, broken sun visor… saw some ideas on fixing it here on the forum. Went with an aluminum repair part.
AMTHKNO 2Pcs Upgrade Aluminum Alloy Sun Visor Repair kit for Jeep Wrangler, Sun Visor Clips for Jeep Wrangler JK 2018, Wrangler 2018-2022, Gladiator 2020-2022 - W/Hardware and User Manual (Red) https://a.co/d/0F9r4cf
Jasonlatchaw
Jason
Shawnee, ok
2019 JLU
So I had this rattle too and this was the forum I looked to for an answer. Skeptically I was led to the visor. As soon as I unfastened and lowered the driver's visor, this bolt fell out. It had obviously loosened itself as all the other three were loose. That fixed.it.for me.
Jeep Wrangler JL Rattle behind dash - driver side PXL_20230312_214704016
Jeep Wrangler JL Rattle behind dash - driver side PXL_20230312_214706491
Msnellen
Melissa
Jefferson City, mo
2023 Jeep Wrangler Rubicon 392
I get this rattle noise when it’s 70 degrees or lower. It’s been hot here so haven’t had to listen to it for a while. But since it’s cooler it has started back up. It sounds like a rattle in the steering column area. I have taken the Jeep to my local dealer. They couldn’t get it to make the noise.
