Questionable Stock Windshield Wipers
DaltonGang
Doesn't Play Well With Others
4 years with the factory blades and they still work really good.
Garage kept??
Because I can only get 1 1/2 years of good use out of any blade I buy, no matter how expensive.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
My 2019 had bad wipers. My 2021 is legit. Same part from one to the other so what's the difference? My 2021 blades are square to the windshield. The 2019 needed an adjustment. Had to twist the wiper arm to get the blade to sit correctly on the windshield now it's legit. ?
cosine
NY
2019 Wrangler Sport jl
Gone Postal
i replaced my stock wipers which lasted 4 years with bosch icon. i dont bother with the rear wiper since i dont use it.
Ang1Sgt
Rochester, New York
2020 Willys 2 door, 2024 Subaru Outback,
Retired X2
I am pretty anal about my blades on my vehicles. After 10 years of swapping blades out at a BIG BOX Auto Parts store, I do highly recommend the Bosch blades myself. They have added one or two level above their standard beam blade, but they all seem to work well.
One thing that can really extend the life of you blades is CLEANING the blade edges every time you clean your windshield or top off fluids in your Jeep. I also look and inspect the blades carefully. IF they are starting to ”ROLL OVER”, it’s time to change them. What I call rolling over is that the blades take a set and the wiping edge seems to be bent in one direction or the other. Does FINE working aross the grain, but going with it is where you get your streeks or smears. The blade SHOULD be when on edge, straight up and down. If it’s laid over in one direction or another then replace.
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
Product recommendation?
I used the Adam’s spray on version but they also make a windshield sealant that works awesome. I like the spray on ceramic because it’s very easy and forgiving to apply and lasts 6 months to a year (YMMV). That plus RainX fluid and water just beads off like crazy.
jromanmd
Jon
Annapolis
www.instagram.com
2023 Jeep Wrangler Rubicon
I aree with @Maverick909 I use Turtle Wax 53409 Hybrid Solutions Ceramic Spray Coating. I put this on the Windshield and it lasts for quite a while.
Makes the water bead off while driving and keeps the wipers nice and buttery smooth.
