Punk'n on 37's
JL1LE
Neal
Denver, CO
2018 JLU White Rubicon
Looks good! What lug nut's did you get?
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
from Amazon
ZY Wheel 14mm x 1.5 Thread Size 51mm Long Set of 24pcs Small Diameter 7 Spline Drive Black Lug Nuts Closed End with 2 Keys
RUSTYS
Rusty
PA
JLUR
Guitar slinger
4.75 offset and no rubbing in front and had to remove lower rear cover and slight heat gun to rear liner
Hey quick question about the front bumper. I did NOT order the metal bumpers knowing I would be replacing them with aftermarket. Now I'm installing the same lift and tires as you this weekend and wanted to know if you think I'll be ok with the front bumper and any rubbing? Did you ever run this setup with the bumper extensions on? Thanks
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
One word, Sweet! It took a long time for the Punk`n to show up here in NJ. It’s a great color and you have a great build there ! Any future plans for it?
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
should be fine I just like the stubby bumper look
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
would like lift to be around a inch higher and full skids underneath. just added a front camera to help wheeling
richk225
Rich
New Jersey
Was the front camera a pia to install? Do you have to use a Mopar camera?
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
I have the Tazer and the Tazer RCA plug and you have to remove the head unit to connect to the headunit plug then mounted camera in sway bar skid plate. the resolution is not as good as the rear camera but just need to see rocks, see the pictures as the one with the planter my left wheel was just hitting the curb
richk225
Rich
New Jersey
Thanks, now seeing it I think it’s worth it. That’s a pretty good view
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
Made a licence plate relocator bracket and camera housing also used stock third brake light in this design. this design allows me to have the bracket for my CB antenna and a flag for the sand dunes. I didnt like the ones online as the mount the camera lower and don't utilizes the stock third brake light, added the JL grill on the bottom that lets the orange come thru. Next upgrade will be the new rear bumper so I wont have to worry about losing the rear plate anymore as all the plastic tabs are broken.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
Wow, now that's uber impressive. Sometimes I wonder why the "vendors" don't design things with the features people want, like you've done. Kudos on a great job!
Oh, and the Punk'n is bad*ss, stands out in the crowd.
Mud2Sno
Mud2Sno
Mickey
2018 JLUR Rubicon
couple more upgrades on the underside and back
