JL1LE
- Neal
- Jan 25, 2018
- Denver, CO
- 2018 JLU White Rubicon
Looks good! What lug nut's did you get?
No, and plenty of power due to the 8 speed transDid you need to re-gear for the 37s?
from AmazonLooks good! What lug nut's did you get?
Hey quick question about the front bumper. I did NOT order the metal bumpers knowing I would be replacing them with aftermarket. Now I'm installing the same lift and tires as you this weekend and wanted to know if you think I'll be ok with the front bumper and any rubbing? Did you ever run this setup with the bumper extensions on? Thanks4.75 offset and no rubbing in front and had to remove lower rear cover and slight heat gun to rear liner
should be fine I just like the stubby bumper lookHey quick question about the front bumper. I did NOT order the metal bumpers knowing I would be replacing them with aftermarket. Now I'm installing the same lift and tires as you this weekend and wanted to know if you think I'll be ok with the front bumper and any rubbing? Did you ever run this setup with the bumper extensions on? Thanks
would like lift to be around a inch higher and full skids underneath. just added a front camera to help wheelingOne word, Sweet! It took a long time for the Punk`n to show up here in NJ. It’s a great color and you have a great build there ! Any future plans for it?
I have the Tazer and the Tazer RCA plug and you have to remove the head unit to connect to the headunit plug then mounted camera in sway bar skid plate. the resolution is not as good as the rear camera but just need to see rocks, see the pictures as the one with the planter my left wheel was just hitting the curbWas the front camera a pia to install? Do you have to use a Mopar camera?
Wow, now that's uber impressive. Sometimes I wonder why the "vendors" don't design things with the features people want, like you've done. Kudos on a great job!Made a licence plate relocator bracket and camera housing also used stock third brake light in this design. this design allows me to have the bracket for my CB antenna and a flag for the sand dunes. I didnt like the ones online as the mount the camera lower and don't utilizes the stock third brake light, added the JL grill on the bottom that lets the orange come thru. Next upgrade will be the new rear bumper so I wont have to worry about losing the rear plate anymore as all the plastic tabs are broken.
