Old Dogger
- Bill
- Nov 15, 2021
- Cave Creek Arizona
- 2013 JKR, 2016 JKURHR 2018 JLR, 2025 Gladiator Mojave.
- Occupation
- Retired
Interesting Post
The fix for the pentistar upgrade engine detonation/spark knock everyone complains about. I've been a ase certified senior master tech at a Ford dealer for 7 years. Really wanted a wrangler so I bought a 2020 jl sport brand new. 16,000 miles and After 3 visits to my local dodge dealer for the noise, advising them I know what I'm talking about and have been in this industry for almost a decade, and shooting down the "no problem found" they tried to tell me the first visit, and a pcm update i told them will not fix a base engine issuie the second visit. Told them to check these components at first visit and they never did. The 3.6 pentistar upgrade engine has a new pcv valve design compared to the 3.6 jk. By nature and bad design it will consume more oil then normal. Consuming oil=carbon build up. When you have a 11.1 high compression engine, a little carbon build up on the piston tops will turn it into a 12:1 compression engine when taking what little space is left in the combustion chamber at top dead center and filling it with carbon deposits. No pump gas will run in a 12.1 engine without detonating really bad. After 40 days at the dealer I got ahold of the field service technician with dodge and told him what I though was happening and what needed to be done. After threatening to lemon law it in ny they decided to listen to my advice. After a little research I found dodge is making a new pcv valve for the jl wrangler, but it's so new and still being produced that it dosnt even show a part number for the new design pcv valve yet. Why would they redesign a pcv valve if it wasnt having issuies? After they relayed the info to the dealer and dodge approved the updated pcv valve replacement and a bg air/fuel induction service to clean the carbon out, it runs amazing and zero detonation on a 90° day at low rpm lugging it, tried as hard as I could and it would not detonate when before it sounded like I was dragging a chain link fence under my oil pan. I don't think you would need a catch can anymore as the main reason for excessive oil consumption was the pcv. Felt great proving them wrong, but still un easy after the amount of detonating this poor engine has gone threw, doubt I will keep it past powertrain after this. Don't let the dealer tell you it's normal, detonation is NOT normal under any condition and I've seen 5.0 f150s from 2018-2019 crack pistons and bend rods from detonating (common issuie on some 5.0 coyotes from that year at specific build dates) . At the very least it will cause alot of wear on bearing and rotational parts inside the engine. Do not let them fool you into thinking it's normal because of there incompetence.
