Premium soft top care
jimim
NEPA
2020 Rubicon, 2017 Tahoe LTZ
As title says it’s a premium twill soft top for my 2020.
I never owned a soft top.
what is my best product for protecting it?
I see chemical guys have one. Best top has one.
also for my weekly washes I assume I can use my typical suds I use on my paint. I use just suds. No other waxes or chemicals in it.
I’m just trying to get a game plan together so I don’t ruin it.
I use Wolfgang products for all my care but never noticed a soft top cleaner or protectant from them.
thanks all!
631_Islander
Area Code 631, NY
2020 Unlimited Rubicon with 8 speed and 3.6L Pentastar without eTorque.
Business Development Manager for the US arm of major global Fortune 500 Japanese Electronic Components manufacturer headquartered in Osaka, Japan.
I got the dual top option when I ordered my JLUR. A lot of us use this for soft top cleaning. 32 oz should be enough for one setting. Recommend applying once every two or three months: 303 Fabric Guard - For Outdoor Fabrics - Restores Water Repellency To Factory New Levels - Repels Moisture - Prevents Stains - Safe For All Fabrics, 32 fl. oz. (30606CSR). REMOVE YOUR VINYL SOFTOP WINDOWS BEFORE APPLYING THIS.
https://www.amazon.com/dp/B00KMYYQ36/ref=cm_sw_r_cp_api_glt_fabc_PMMWJYVC0TCYB86S63J9?psc=1
For Vinyl Windows only use this: 303 (30207CSR) Multi Surface Cleaner Spray, All Purpose Cleaner for Home, Patio, Car Care and Outdoor, 32 fl. Oz https://www.amazon.com/dp/B00JAMYDFC/ref=cm_sw_r_cp_api_glt_fabc_GA7B50NNHDQ9R5Y2887F
jimim
NEPA
Oh nice I didn’t realize 303 had fabric protectant. No residue left behind right? Thanks! Jim
four low
central New York
2018 JL
I vacuumed my fabric convertible tops, a soft wall brush worked great to pull out dust and grime. Washing can grind dirt in, so be gentle
jimim
NEPA
Really? I figured a strong stream of water should be able to pull anything out of the fabric.
Care208
Andy
Palm Beach County Fl
2019 Sahara Unlimited
Convertible Top Video
I have the sky one touch and a 2013 VW ragtop, both need some love, I like the chemical guys stuff... am planning on getting it done this weekend will let you know how it goes!
jimim
NEPA
https://www.autogeek.net/raggtopp-premium-fabric-kit.html
I ended up with this company. A local detail shop I used to use was doing a top yesterday. This is what he has used for a while now. I liked the process and the spray on for the protectant. He has been pleased and I have known him for years. I used to take my trucks to him before I got into doing them myself.
I also bought the window protectant.
SSinGA
Sean
Alabama
2020 JT, 2018 JLUR, 2016 JKRHR, 2012 JKU Sahara
Crawldad
Hagerstown, MD
'21 2dr wrangler rubicon, '18 Ram3500
on my previous wranglers... soft tops last much longer if you do not use soap on them. the high detergent stuff that car washes use will remove all the chemical treatments that protect your top from UV.
just my opinion, but it's best to use only water on the soft tops.
water and a soft brush is all you need for the top.
on the plastic windows, water no brush no rubbing at all. only hose them and very very lightly swab with a soft sponge or cloth. again, no rubbing. mild soap is ok on the windows, but rubbing the grit is bad news.
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
jimim
NEPA
I never ever use car wash anything only water to power wash off salt in winter or heavy mud. They soap they use takes off waxes and sealers.
that’s good to know about no soap on the tops. Makes sense. Like I said before rarely on any truck I have owned my room never needs subs unless a bird craps on it
631_Islander
Area Code 631, NY
Not that I am aware of.
flyer92
Nevada
Agree 100% on both of these recommendations. No sense dropping lots of $$$ on cleaners that actually leach the chemical treatments that are already impregnated in the fabric. However, you will eventually need something to clean the windows when they start getting hazy, and to buff out the micro-scratches that are inevitable, no matter how careful you are. I've used Meguiar's for a long time, but it seems like the formula has changed somewhat in recent years and requires some elbow grease to apply. Lots of folks in this forum recommended Plexus, which seems to be extremely effective and easy to use on all plastics. My JL is only a few weeks old, so not going to apply it until I absolutely have to (less is always better), but definitely look forward to seeing the difference.
