PPE Transmission Pan
CarbonSteel
I picked one of these up to install when I change the fluid. This thing is a beast and has a drain plug with integral magnet and the ability to add a temp probe if desired.
Jeep Wrangler JL PPE Transmission Pan 20220120_102039
Jeep Wrangler JL PPE Transmission Pan 20220120_111836
Jeep Wrangler JL PPE Transmission Pan 20220120_111826
BDinTX
Dallas, Tx
Nice find! Let us know how the trans service goes.
cs2k
Clarence
San Diego, CA
2021 JLUR 2.0
Engineer
Is this the version with the 1 extra quart, 1.5 extra quart or the 2.5 extra quart of capacity?
When you install it, i'd love to know
- How much extra height does it add to your transmission pan? I have an engine/transmission skid and there isn't a ton of room between the skid and the trans pan.
- How much improvement do you notice in terms of its cooling performance?
- How does the quality of the builtin filter look compared to the OEM unit?
- This unit doesn't seem to have the builtin magnets (other than the plug) like the OEM unit, are additional magnets present?
  • Like
Reactions: J0E
CarbonSteel
CarbonSteel
- This is the 1.5QT extra capacity pan
- Attached are the dimensions of the pan. I have a MC skid system, but in all the photos that I have seen with it mounted, clearance should not be an issue.
- Given that the skid plate system blocks most of the air, I would not expect to have any appreciable change in cooling performance (up or down), but will see once I change it out.
- The filter is removable as is the OEM on a Wrangler. The PPE filter is very well built, and it is quite a bit larger than the OEM (not interchangeable).
- The PPE pan does not have additional magnets--only the drain plug, but that magnet is about 3/4" in diameter.
Jeep Wrangler JL PPE Transmission Pan basic_dimensions_1_4
Jeep Wrangler JL PPE Transmission Pan 20220120_155921
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
That looks like a must have pan if you don't have skids. I don't yet and high centered my JLR on the auto transmission pan. All 4 wheels spun easily, I'd say 95% of the weight was on the pan. I was pretty nervous when my buddy pulled me out, but all it did was scratch the hell out of the pan. The offending rock didn't have any sharp points and I got lucky.
I'll get skids when I get new axles/lift. But if you've got full skids, I don't see much benefit to upgrading the pan.
It's an amazing looking pan, too bad you can see it unless you're under the Jeep.
CarbonSteel
CarbonSteel
For me a few things:
1. Increased oil capacity vs. OEM
2. Magnetic drain plug to facilitate a few drain and refill to replace most of the fluid so that I do not have to drop the pan.
3. Larger filter media vs. OEM
aformenius
Alex
LA, CA
2019 Wrangler JLU Rubicon
Did you have any issues with the oil pan making contact with the exhaust tube?
I seem to be having that issue with this pan atm.
CarbonSteel
CarbonSteel
I actually sold mine for this reason--I bought the powder coated version and did not want to grind on the pan; note that PPE states for the 3.6L you may have to grind the fins down.
PPE has since introduced a new pan that is properly designed and is already machined to clear the exhaust pipe. With that said, the other thing that I did not like was the proprietary filter they use versus the OEM filter.
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
So I’m literally at the step of replacing the pan today- and I noticed the bolt holes were larger on the pan ppe sent me. The part number is 228053400. Looks like a pan for a ecodiesel hero GC. (I assume that’s grand Cherokee?). PPE is obviously closed. Great. I just looked at their sight again, and it lists 228153400 part number, different. I’m assuming the pan I have is incompatible? If so, I’ll have to throw the oem pan back on, get PPE to switch and install the new pan when it comes in. Am I missing something?
Jeep Wrangler JL PPE Transmission Pan image
2020 Rubi
Scot
2020 JLU Rubicon
I also have this pan. When I'm wheeling at an extreme vertical angle, I lose the ability to shift into reverse. The R just blinks. If I put it in drive it goes D 6th gear at a stop. If I go to Manual it says M first gear but it's actually in sixth gear. I had the correct amount of fluid the first time I had this problem. I've since over filled the fluid level by a 1/2 quart. I still have the same problem. Has anyone else had this problem and what did you do to fix it? Once I get my Jeep onto level ground it goes back to functioning normally.
Hercules
Clearwater, FL
Not yet. But that sure is weird. I’ll keep an eye out when I wheel in a couple of weeks
2020 Rubi
Scot
2020 JLU Rubicon
I recommend testing it out before you get yourself in a bad situation. Climb something steep and just stop on the incline. Sit a few seconds and then move the shifter to reverse. Hopefully yours will still go into reverse. Good Luck.
FYI: The pan looks great. The install was easy. I'm hoping I can find a fix and not have to replace the pan, but I need it working properly when I'm wheeling.
azjl#3
North AZ
sounds like not a pan problem, other issue you had or now have.
