Please help: code p012d
Ladydixon
Elizabeth
Illinois
2021 wrangler unlimited
2021 2.0 turbo engine had code p0017 replaced camshaft position sensor and put it back together. That code is gone but now I have a p012d and it's says service electronic throttle soon. Its also stuck in limp mode.
Rando
Randy
Bellaava15!!
2018 Wrangler JLU
Did you find an answer? I'm chasing a similar issue, all codes seem to be fixable but dealer said I either need timing or a new engine.
alphawolff
california
2021 JLU
P012D-TURBOCHARGER/SUPERCHARGER INLET AIR PRESSURE SENSOR 1 CIRCUIT HIGH
This is a wiring issue with the inlet boost sensor. Either the module, the sensor, or the wiring in between. It has nothing to do with the timing or engine.
Rando
Randy
Bellaava15!!
2018 Wrangler JLU
I know it has nothing to do with timing and I was asking what OP solution was ...... I have this code. I don't have any timing codes and I can look up the code and it tells me the same thing you did. Thanks but no thanks.
alphawolff
california
2021 JLU
.....That's the repair procedure. Do you think a code just tells you what to replace? Diagnostic doesn't work like that.
Check resistance of the wiring and pin tension. If that is good then replace the sensor. If it comes back replace the module.
Rando
Randy
Bellaava15!!
2018 Wrangler JLU
I know how diagnostics work, I am an AG tech I deal with equipment that is 10 times more complicated than the auto world. Which I was in before AG. I have done everything to diagnose the problem to no avail I sent it to the dealer in the summer because I work 80+ hours a week and they wanted to tell me they would suggest timing and if that didn't fix it replace the engine........ Hence why I am am asking someone what THEY NOT YOU found that was causing said code. You know like experienced techs do when they have hit a wall.....
Swilms
Kentucky
2018 JL unlimited hybrid
Did you find the solution? I am getting the same code after changing the cam sensor?
