Pizza Cutter Size List & Appreciation Thread
jadmt
jeff
montana
I have joined the M/T baja boss A/T life as well. I really like them so far. They drive great and are 100x better then the factory 2/3 worn out firestone destination M/T. Rubicon take of lift and fenders pair really well with them. Lots of talk from the techs how I chose the wrong tire and should have went 12.5. Hopefully will be getting them in the dirt soon.
They are great tires..if you want at little better stance you can do BORA 1" spacers..I use them when I am running those on stock wheels..
Derrick20JL
Derrick
CANTON, GA
2020 Willy 2 Door
That looks so good with the Rubi fenders! Did you do just fronts? Or rears also? What size tire did you end up getting?
I did both the front and the rears. I dont have the right bumper to make them match up so it looks a little weird in the rear, but it'll look fine once I get an aftermarket rear bumper.
Derrick20JL
Derrick
CANTON, GA
2020 Willy 2 Door
Im thinking about doing spacers just to get them out to the edge of the fenders. Just a little un-eased with the idea of wheeling with spacers.
jadmt
jeff
montana
I have wheeled for years with spacers and never had an issue....1" are the lowest you can go without trimming your studs..and put the tires just at the edges..
Jeep Wrangler JL Pizza Cutter Size List & Appreciation Thread tempImagetP7FTF
Derrick20JL
Derrick
CANTON, GA
2020 Willy 2 Door
That does look a lot better. Its good to know that there is no trimming of studs with a 1 inch. Yeah and I dont treat it like a rock bouncer or anything so Im sure it would be fine. After seeing your set up I'll look at them a lot harder.
CapeArt
BB
Cape Cod
2023 JL Sport S, Porsche 987S, MazdaSpeed Miata
2021 willys no lift. Falken wildpeak at4 255/80/17.
So far so good . No issues. Nice on road ride improvement over factory mud terrains.
What is the hwy tire noise like?
turboaaron
Aaron
2021 wrangler willys jlu, 1987 Buick Grand National, 2014 mustang gt
Zero noise so far . I was concerned about the heavier tire and the e load range, but
These tires make it feel brand new. Running 37 psi .
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
dav;d
Las Vegas
Wrangler JLU Rubicon
Gangplank
Vero Beach, FL
2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
The recent pizza cutter post motivated me to start this thread so that all of us "pizza cutter" tire lovers can have information and photos on available sizes all in one place. Below are some popular pizza cutter tire sizes, and links to JLs with photos (where available). I've also listed some of the available tires in the less well-known sizes. If anyone has any additional photos or information to add, let me know and I'll update this post.
235/80/R17 (31.8" x 9.3")
33x10.5R17 (32.8" x 10.5")
255/80R17 (33.1" x 10.0")
34x10.5R17 (33.5" x 10.5")
255/85R17 (34.5" x 10")
35x10.5R17 (34.5" x 10.5")
37x11.5R17 (36.5" x 11.5")
37x11.5R18 (36.5" x 11.5")
Wheels
All the sizes should work fine on stock wheels but there are wheels that are narrower than the 7.5" wide stock JL wheels. Other Mopar products, such as the Dodge Journey of certain years, had narrow wheels that match the JL hub bore of 71.5mm and the 5x127 bolt pattern. Here are some options:
Another pizza cutter to add to the list is the Nitto Recon Grappler 35 x 11.5. I have them on my 2021 JLU Willys with Mopar Lift on the stock wheels.
im thinking I can probably fit 37 x 11.5 Recon Grapplers next time
Jeep Wrangler JL Pizza Cutter Size List & Appreciation Thread IMG_1761
Jeep Wrangler JL Pizza Cutter Size List & Appreciation Thread IMG_1755
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Just to keep this thread current, Toyo RT Pro now lists a 38x11.50R17. That's gotta qualify as "pizza cutter if the current list in the first post has 37x11.50R17.
