PCV valve location?
Driggs
New England
Many
Does anyone know where on the engine the PCV valve is located? Can’t seem to find any information on it for the JL’s. Already had it replaced once under warranty, trying it myself this time.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
If it has already been replaced once, it probably isn’t what’s wrong.
Driggs
Driggs
New England
Many
Oil seepage on side and bottom of engine from the seems only at highway speeds, and once again some oil in the engine air filter. Not a oil cooler/filter issue and isn’t my rear main seal. Only thing left I can think of is the PCV.
mwilk012
Oklahoma
Service
How bad is the oil leak?
If the problem you’re describing was the pcv valve, you are talking about the effects of both too much and too little air flow. It just doesn’t add up.
Driggs
Driggs
New England
Many
Just seeps enough to coat the bottom and lower passenger side of the engine, doesn’t drip. Talked to a few others with the same problem and no answers. Took it to two mechanics and they didn’t know why either. Oil in the air filter housing is a lot less than the previous time.
