Passive entry only works on tailgate...
frankjc
Frank
Massachusetts
2018 Wrangler, 2012 Liberty, 2004 super Glide.
Hi. 2018 JLU, the passive entry is only working on the tailgate, not on the doors. I've checked for bent pins on the door harnesses, and broken wires. I did find that on the driver's door harness, the connector inside the door panel was not fully plugged in. Plugging that in all the way solved the problems with the power mirrors and blind spot monitor. It IS turned on in the Uconnect menu.
Any ideas where to look next??
Thanks.
xj2jk2jlu
NY
2023 JLURXR 3.6 eTorque
My sensor went bad twice in passenger handle. Have the dealer check it out if possible.
frankjc
Frank
Massachusetts
How about the "cap"....the one on the driver's door is loose, and can be pulled off easily. I guess there is a magnet in it?
AndySpill
Andy
Pittsburgh
2018 JL Sahara
frankjc
Frank
Massachusetts
Factory option.
frankjc
Frank
Massachusetts
So...i got home from work, decided to pull the door handles off. The driver's door handle was not even plugged in. I have that side working now. Passenger side was plugged in, i unplugged it and plugged it back in, still doesn't work. Im just glad the driver's side works. There is paint overspray on both doors. The dealer must have painted the doors and forgot to plug things in. Im just glad the drivers door works now. Jeeps keep me busy. We also have a liberty which is my daily driver. I need to replace the radiator in that.
frankjc
Frank
Massachusetts
Also, it seems to be missing whatever covers the screw holes for the handles.
