Overheating and losing power
Medsker
Medsker
Jon
South Jordan, Utah
Retired Engineer
Thanks guys! When I get out of the hospital I'll get some pics to send to RPMExtreme and will update when I find something out.
Medsker
Medsker
Jon
South Jordan, Utah
Retired Engineer
Here are the pics I took:
Jeep Wrangler JL Overheating and losing power 20230928_143743
Jeep Wrangler JL Overheating and losing power 20230928_143719
Jeep Wrangler JL Overheating and losing power 20230928_143728
Is this the right unit?
Medsker
Medsker
Jon
South Jordan, Utah
Retired Engineer
I sent the pics off to Jon and we'll see if he thinks it's worth giving it a shot.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I am sure it will work
You could cut back the tape on the wiring loom and see if the wire colors mach the diagram
Here is the wiring loom tape I use. It works great and looks factory original
https://www.amazon.com/gp/product/B095K2FBTV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Did you see my post on the Tahoe trip
Also I am in the processes of installing the larger 240 amp alternator / Z fuse / 850 watt fan
I think the 2.0 already has this set up
Medsker
Medsker
Jon
South Jordan, Utah
Retired Engineer
I did see your post. I'm so happy you found something that works for you...hopefully for me too. Tape is in my cart, thanks! I'll look at the wiring when I get feeling a little better from my surgery. I'm supposed to take it easy for a week.
elliott9
Keith
Arizona
Wrangler JLUR
OP did this work out for you? If so got a link to what you bought?
Medsker
Medsker
Jon
South Jordan, Utah
Retired Engineer
Before I could try anything mine overheated on a steep climb and caught on fire. I think the engine warped enough that some oil or gas or something flammable hit the hot turbo and caught on fire. I bought a used 392 with 3000 miles on it to replace it. I've put 31,000 miles on it in the last year and so far it's worked flawlessly.
Jeep Wrangler JL Overheating and losing power 20240613_124422
Old Dogger
Bill
Cave Creek Arizona
WOW.. Nasty! It's a good thing that you didn't burn up with it....:facepalm:
