Onboard Air Mounts
jadewolf
2012 JK Sport (sold), 2021 JL Rubicon
rohdawg
Long Island, New York
Merchant Marine
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
The Innovative Products fits under the seat on a 2 door. I think you’d be hard pressed to find a better system than this.
https://innovativeatproducts.com/sh...ith-arb-twin-compressor-ckmta12-package-deal/
This!!
This system is one of my favorite things I've done with my build.
Places two output ports, one under each seat, you connect a "Y" hose to each one and connect all 4 tires together. It equalizes pressure in all 4 tires and allows you to air down all 4 at once. When it comes time to air up they all inflate together and with the included adjustable pressure relief valve you just run the compressor until it pops off and they're all inflated perfectly and equally.
jadewolf
jadewolf
This!!
Well, dang. That's just about perfect! Can you still roll the seat forward with that setup?
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Yep, rolls forward and backward just fine. (It's tight though, your hose management needs to be on point) I was able to fit my ham radio under the same seat as well. Just barely. But it fits.
Here’s some photos, in no particular order, of my install. (Sorry for the mess, I was doing a lot of installs in one week for an upcoming trip)
Jeep Wrangler JL Onboard Air Mounts 2F1D0AA0-97FF-4957-8A77-E07561D1F07D
Jeep Wrangler JL Onboard Air Mounts 10B25984-5A20-4319-8085-43E80F0E5F59
Jeep Wrangler JL Onboard Air Mounts BEFD9F8A-973D-4E42-8E10-61A242C7BBE9
Jeep Wrangler JL Onboard Air Mounts 25DB6233-9160-4153-8EC8-A46BE1D5EAF7
Jeep Wrangler JL Onboard Air Mounts E50BEB73-6B56-45E7-9C99-9AAE8F9EA79B
Jeep Wrangler JL Onboard Air Mounts 682861D3-022F-4E55-86AF-2ED3CD9A219D
jadewolf
jadewolf
Ok, that's fantastic! Thanks for sharing this. Updating my wishlist. I think this is the ticket right here.
rohdawg
Merchant Marine
@Jeepeto beat me to the punch, so I’ll just second everything he said and add - when it’s all said and done, it’s a super-clean install. Very well thought out.
cornercanyon
bruce
Texas Hill Country
2014 JKUR, 2021 JLUR XR
. . . realizing each day–
I like Jeepeto's install very much; though I am leaning toward an underhood location. Smaller ARB pump with a clean under hood install and remote chucks(s) at the front bumper. Especially in a 2 door it is worth a look, ( YouTube video link)?
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Sorry for stealing your thunder ?
rohdawg
Merchant Marine
No way! You nailed it, brother. I was hoping you’d see the thread and add your experience with it. Especially since you just took your rig out and put the system to work. :like:
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
I use the pony tailed guys ([Banned Site]) mount. puts it under the brake booster on the firewall. Also made an extension hose and bracket to mount an air chuck by my winch.
no link, can't even type in the dudes name... weird.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Put mine under the hood on the firewall, drivers side. Works perfect!
https://www.grimmoffroad.com/jl-arb-twin-compressor-mounting-bracket-kit.html
On my 2019 JLR I used the M.O.R.E mount for an ARB twin compressor inside the cab behind the driver's seat. Then I moved the same compressor to an under the passenger seat mount on a 2020 JT Mojave. And then I moved the same compressor again to an under hood mount on my 2021 JLUR, using the Grimm Off Road mounting kit.
The Grimm off road mounting kit is the most complete kit, and mounts the compressor in the best place, that is easiest to use, and doesn't make a lot of noise or heat in the cab.
Jeep Wrangler JL Onboard Air Mounts JLUR Twin Air
cornercanyon
bruce
Texas Hill Country
Oh, uses the twin ARB and fits under the hood. That is sweet—
