Oily rear shock? Normal?
btrebelh
Illinois
21 JLUR XR
Just installed these 3 months ago. Driver’s side rear shock is definitely oilier than passenger’s. Is this normal or is the seal leaking?
Teraflex Falcon 3.3 quick adjust.
Jeep Wrangler JL Oily rear shock?  Normal? IMG_1220
Jeep Wrangler JL Oily rear shock?  Normal? IMG_1221
Jeep Wrangler JL Oily rear shock?  Normal? IMG_1222
yokramer
Snark Incarnate
Well that’s pretty disheartening for expensive Teraflex shocks to be leaking after 3 months and no off road yet.
I would take as many pictures of it as you can and reach out to them. Faulty new products happen and they seem like a company that will take care of it.
jadmt
jeff
montana
I know for a fact on the Falcons there is some residue under the dust cap that has nothing to do with the shock oil itself it is just used in assembly. i would clean it and see if it comes back..if it does then Teraflex has awesome customer service.
AccuTunedJL
El Cajon, CA
2018 Jeep JL Rubicon
x2 with this. During assembly often times there is a little bit of oil in the bump cap and rod guide. If it's not thoroughly cleaned out it can seep out the cap giving the impression the shock seal is failing.
However, if you are just noticing this now, 3 months later, that's not a good sign.
Clean it off and check back in a few days to see if it comes back. Hopefully Falcon can help out if it is leaking.
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
Just for due diligence sake: you didn't by chance get shocks that are too short for your setup?
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
Yes, that is always how I treat a leaky shock, wipe it down and see if the oily residue returns.
