Oil filter brand
What brand oil filter do you use?
  • Total voters
    143
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
Wix used to be tops. I had to go to OReilly’s to get them where I lived. Surely they’re still very good.
They are. They are also sold at NAPA under NAPA gold.
LARSONEM
Eric
Eaton Rapids, MI
2022 Jeep Wrangler Rubicon XR Unlimited, 2021 Jeep Willys 2 door
I’ve pretty much always used OEM filters; Mopar, AC Delco, Honda or John Deere preferring to stay with what the manufacturer originally installed. Figured if it was good enough to be originally installed, it was good enough to continue using. Over the last 50 years I might have installed a Fram 2 or 3 times because I just couldn’t find an OEM filter and didn’t want to specifically go to a dealership parts counter to find one.
That said, I changed the oil in my 2021 Willys the other night. I bought a Mopar filter as usual. I did look at the Mobil 1 filter which mentioned it being an extended drain interval filter and it cost about $1 more than the Mopar.
NWJeepr
Twin Peaks
2025 Wrangler 2-door
Mopar filters are WIX.
Current source? My guess would have been a division of Champion like the AcDelco's I use on my GM vehicles. Don't forget, the 2.0 uses a metal spin-on versus the 3.6's paper cartridge.
Used to be. Wix has definitely changed their supplier for a good number of their filters.
True, however, Wix changed suppliers, and that trickled down to the Napa Gold as well.
gek
Code Monkey
JEEP4U
Richard
2021 Jeep Wrangler
Wix XP filters utilized in all vehicles
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
I use one of 3 in my Pentastars:
Fram XG
Fram TG
Champ Luber-Finer XL
All 3 are 99% efficiency @ 20 micron.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Please explain.
Using non OEM oil and non OEM filter are not the same. Using non OEM filter is like using non OEM spark plugs. Are non OEM filters and spark plugs better, probably, but I would want to stick to OEM
Jtphoto
Thunder Bay ON
Nope, Mopar is a completely different animal. It has no similarity to others, that's why I use Mopar.
Interesting, since when did they change it … Wix use to make the Mopar 3.6 filters.
Jtphoto
Thunder Bay ON
Well this solves that … That isn’t the same WIX filter in the video that I have always used.
This WIX filter (NAPA Gold 100010) is virtually identical to the Mopar 64 pleat filter in the video.
Jeep Wrangler JL Oil filter brand IMG_1076
Jeep Wrangler JL Oil filter brand IMG_1077
Jeep Wrangler JL Oil filter brand IMG_1078
